Will i ever learn ?
Started by goose63, May 09, 2015, 06:12:33 PM
goose63
You would think by now I would know better
goose
thank you to all the vets
Brad_bb
I did it this week too cutting stickers.
Ocklawahaboy
So far, I have only hit one tooth on mill metal.    Just one, knock on wood.
acrosteve
Me too, fresh blade made it hurt even worse.  Just the 2nd pass with it.
Timberking B-20
POSTON WIDEHEAD
....it depends. Are you a metal worker and found a piece of wood or are you a wood worker and found a piece of metal?......asked the Goat.
goose63
Goat if I could weld wood I would make a DanG good wood worker
  I did fing some good looking pine
goose
East ky logging
Yea my woodmizer will cut about anything but the backstops and believe me I've tried several times
They who can give up essential liberty to obtain a little temporary safety deserve neither liberty or safety- Benjamin Franklin
We can all chuckle when someone else does it....[spoiler]because our time is coming...AGAIN.[/spoiler]
goose63
goose
rooster 58
Yup. This past Thursday I scalped a back support.  I looked first and said that'll make it. But no dice
fishfighter
Quote from: rooster 58 on May 09, 2015, 08:45:26 PM
Did that twice. Talk about wanting to bang my head on a tree. ;D
And if you bang the front side, it will not have any teeth either.   ::)  :D
Ocklawahaboy
Some day they will make a mill where the stops and blade height are coordinated so that doesn't happen.
I believe that EZ Boardwalk has a device that will not allow the blade to hit the sawmill.  Someone chime in and correct me or verify this.
UN Hooker
I could see this happening to me, so last weekend while waiting for some paint to dry between coats, I added another mod to the LT-15.    ;D    UN
Retired Toolmaker/Moldmaker
C-4 & C5D TF - 5500 Iron Mule - Restored 4400 Ford Ind. FEL ex Backhoe w/custom built boom w/Valby 360* grapple w/18' reach - 920 Cat w/bucket & forks w/clamp - Peterson 10" WPF - LT-15 - Cooks Catsclaw & Dual tooth setter - many Husky saws
gimpy
I'm a newbie but haven't tried to saw metal, YET. However, I did find out what happens when you saw a log before you put tension on the blade. I've also found out why you want to open the gas can vent. Same with the water bottle vent. Slowly but surely I'm learning some procedures one needs to learn before they start doing the work.
But I am putting sawdust on the ground and having a blast doing it. Just got another load of logs today.
Gimpy old man
Lucky to have a great wife
John Deere 210LE tractor w/Gannon Box
I have a Thomas and my log stops go straight up and down. I marked mine with inch marks,4 inches is really 3½ and 6 is 5½ and so on. That gives me a ½ inch to clear them works out great now. But I was cutting flitches at 6 inches and saw a bad spot that I did not notice when I set them up and dropped down to 4 inches and started to saw.  :o
Delawhere Jack
Jack: Hello, my name is Jack.
Sawyers: Hello Jack.
Jack: I went 18 months without hitting my mill. Then, two weeks ago, I brushed the top of a stop, and milled straight into the short clamp extension.
Lead Sawyer: And how did that make you feel Jack?
Jack: I didn't like it. I don't want to do it again.
Jack: I haven't hit metal in 14 days.......
Nomad
     Ooooh, no.  I've never done anything like that! ::) :D
WoodMizer LT50HDD51-WR
Lucas DSM23-19
fishfighter
Quote from: thecfarm on May 10, 2015, 05:59:05 AM
Can't see that far anymore. :D
zopi
Still better than a fence insulator.
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
Ox
If it's any consolation for anybody I sawed into my backstop the second day I used my new homebuilt mill.
It's now been another two days.
I'm feeling jittery.
:-X
Don_Papenburg
Make them backstops outa wood
gww
Mine are actually wood and I sawed through one today.  Knew I was going to do it but I was to lazy to bang it down with a hammer while halfway through a cut.  The wood is easy to replace.
When I had guides on the guide would hit them and not let me go forward if they where to high.  Same thing with knotts.  I have to have a clean log at the backstop or I have to make my first cut in the middle of the deck and then turn it to the back stop.
I had metal that I was going to use but never got it cut down to the correct size cause using ripped 2x4s ended up being so easy.
Cheers
gww
Ox
Heck, if you're gentle I can see easily replaceable wooden backstops being the cat's pajamas!
