SIPS question for the Timber Frame experts
Started by scsmith42, October 27, 2011, 08:22:03 PM
scsmith42
My house is a "chalet" style that was built in 1990.  It has a 12/12 pitch roof with a cathedral ceiling over 1/2 of the house (see photo below).  There are large laminated beams at the ridge and half way down that support 2 x 6 common rafters, which means that my ceiling insulation only has a value of R19 (and the electric bill bears this out!  >:().
It's time for me to re-roof the house, and at the same time I am evaluating different ways that I can increase my ceiling insulation and reduce my electric and gas bill.  One option that I'm considering would be for me to strip off the old shingles and attach some additional 2 x 6's above the existing rafters, have about 4" of spray foam insulation installed, and then put sheathing and a new roof on top.
Another option would be to use foam board insulation instead of spray foam.
It occured to me today that the simplest installation would be to strip off the old shingles, install some SIPS on top of my exising decking, and then apply roofing on top of the SIPS.
At the end of the day, I'm interested in the best balance between cost, durability and efficiency gains.
Do y'all have any advice to share?  If the SIP route is a good way to go, can you suggest some reputable SIP manufacturers that are reasonably priced?
Thanks much.
Scott
Tom's 3638D Baker band mill
logman
I get my sips from General Panel out of Johnson City, Tn.  They have the best prices around and are close by so shipping cost is low.
LT40HD, 12' ext, 5105 JD tractor, Genie GTH5519 telehandler
M&K Timber Works
Thehardway
Scott,
That's a lot of glass! I am suspecting the glazed area (typically less than R3) has a lot to do with your energy costs perhaps more so than the R19 roof.  Are your AC and heating bills equally high?  What is your solar orientation like in regards to your glazed walls?  Is the inside ceiling very warm to the touch in the summer?
I would definitely get an infrared thermal image done before tearing off the roof.  It is the best way to evaluate the thermal envelope performance.  One on the outside at about 5:00 AM during the winter months and one on the inside around 1:30-2:00 PM on a bright sunny day in the summer would give you a great idea of where your energy is disappearing to.  Better yet rent or buy a thermal imaging camera and you can really analyze every inch and fix all your problems.  Most problems occur around glass, doors, at the roof/eave connection, corners,  wall penetrations such as outlets, chimneys and vents and through the floors.
Should you find the roof is actually the culprit, I might try stripping off the old shingles, screw down some sleepers over the sheathing, spray the whole roof  with 2" of  Polyurethane foam and  install a  reflective corrugated metal roof screwing it to the sleepers.  This will not only make your roof airtight but will allow heat buildup on the back side of the metal to move up and out of the ridge rather than getting trapped on the back of the substrate, building up and pushing through the roof as with a typical cathedral designs.
I would probably stay away from the SIPS for several reasons:
1. Cost
2. Thickness would look strange and require a lot of re-work of rake and eave trim/flashings
3. Foam board  or spray applied direct to sheathing is easier to handle, cheaper and would achieve your purpose.
If it is the glass that is the culprit, your options are very limited but insulated curtains for night time can save a lot of heat loss and special coatings and films can also make an improvement.
The house looks very nice.
Norwood LM2000 24HP w/28' bed, Hudson Oscar 18" 32' bed, Woodmaster 718 planer,  Kubota L185D, Stihl 029, Husqvarna 550XP
scsmith42
Bob, thanks for the insight.  The glass is all double pane, and it faces east.  There is a pine grove on that side of the house, so not much direct sunlight comes in.
The south side of the house does not have many windows, and yes it gets pretty warm upstairs in the summer time.
That's good advice re the SIPs, at $5 - 6 bucks a square foot (I have about 2,800 sq ft of roof) it's a bit cost prohibitive.
Your advice about the alternatives makes sense.  I've run some numbers on screwing 2 x 4's directly over the existing rafters, filling in between them with spray foam applied directly to the existing sheathing, and then applying a new sheathing on top.  I've been quoted $1.50 per sq ft for the spray foam, with me providing the man lift for installation (which I already own).  Running some quick numbers, I would have about $1,800 in materials for 2 x 4's and new sheathing, plus the trim material that I would use.
It looks like for less than 6K in materials, plus some labor, I can add 4" of spray foam insulation on top of the existing roof.  If that saved me $100.00 a month in utility bills, I would recapture my out of pocket costs in less than 6 years, not a bad ROI.
Plus, the combined thickness would be the same as a 2 x 10 rafter, which should not look unusual in terms of thickness.
Considering that my insulation is R19, it seems to me that adding insulation can't but help the situation.
Jim_Rogers
When you say "sips" that means osb foam osb, you may only need foam then osb on top. These cost less and do about the same thing.
You could try asking for these.
Some companies call them curtain walls for side walls, and nail base for roofs.
Good luck with your research.
Jim Rogers
scsmith42
Quote from: Jim_Rogers on October 28, 2011, 07:14:03 PM
Jim Rogers
Jim, thanks for chiming in; I'll check into those as well.
By the way, I just downloaded a drawing that you did back in 2004 of a Trestle Style Saw Horse...  Thanks for all of the great info that you have shared over the years.
VictorH
May I ask what kind of foam you were quoted at $1.50??  Was that per inch or for 2 inches.  Just curious since I spray foam myself and that seems cheap.  In my opinion you would want a closed cell foam.  Fantastic looking home.
losttheplot
Have you got decent ceiling fans up there?
Are they spinning in the right direction?
DON'T BELIEVE EVERYTHING YOU THINK !
ljmathias
Not to run the hijack on fans too far, but I can never remember which way they're supposed to spin- one way in the summer, opposite in the winter.  Compromise I use is to have one spin one way and the other on the other half of the cathedral ceiling spin the opposite- hope is to create a circular pattern from one side to the other.  May not be the best way though...   ???
Lj
LT40, Long tractor with FEL and backhoe, lots of TF tools, beautiful wife of 50 years plus 4 kids, 5 grandsons AND TWO GRANDDAUGHTERS all healthy plus too many ideas and plans and not enough time and energy
John Mc
Here in the Northeast, most folks run fans blowing down in the summer, and up in the winter (at least the folks that remember to change the direction). I don't know if that would change in your area... we don't have much problem with heat in the summer in Vermont. In hotter climates, maybe that would change if you had vents or windows you near the peak in summer in very hot a
Running up in the winter may sound counter-intuitive: heat rises anyway, why would I want to push more heat up to the ceiling? The reason is if blowing down you are fighting the air's natural tendency to rise. It's generally warmer towards middle of the house, so the air has a tendency to rise more there. Since ceiling fans tend not to be placed near the edges of a room, running them up boosts the natural flow, and tends to circulate air throughout the room better - rising up in the middle, settling down around the edges. Blowing down into the middle of the room and fighting this natural flow can basically slow or stop this circulation.
scsmith42
Quote from: VictorH on October 28, 2011, 11:09:25 PM
Victor, that is for open cell foam.  A good friend of mine owns a business that installs spray foam insulation, and he cuts me a special deal.  That price basically is for filling up the entire space between the 2 x 4's.
Closed cell would be better, but it costs more, about $2.00 per sq ft if I recall.
scsmith42
Quote from: losttheplot on October 28, 2011, 11:47:37 PM
Yes, they run 24/7 for most of the year.  Right now they are set for blowing down, which is the summer setting.  I think that they are supposed to pull up in the winter....
Since the bedrooms are upstairs (adjacent to the cathedral ceiling), I need to keep the temps fairly consistent from ceiling to floor, otherwise we're baking at night in the summer time.
Thehardway
Scott,
Do you really need to go back with shingles?  The reason I ask is that with corrugated metal you could eliminate the sheathing altogether and realize further material savings.  If you do want to go back with shingles I would  use 2" of urethane rather than the 3 1/2" open cell.  the cost difference should be minimal for the insurance and additional performance it will provide.  The extra air space you leave under the sheathing will vent the roof and lead to longer shingle life as well.
2" of urethane will easily outperform 3-1/2 of open cell.
As your friend can probably tell you, spray in polyurethane foam has some interesting properties which lead it to perform way beyond it's calculated "R" values.  2" of polyurethane 1.8lb. will perform equivalent to an R40 and is all you need to protect you from temperature ranging from -30 to +240.  In most cases, 4" of spray in polyurethane foam would be the maximum ever installed  on anything and performs at R 63+. After you go past 4" there is little or no additional ROI.
I say this because you really don't need 4" or even 3 1/2" over your R19 roof.  You just need to create a heat/cold barrier and then channel away buildup and eliminate conduction as much as possible and completely eliminate air passage through the roof membrane.
You can find outdoor walk-in freezers which use 2" of urethane and are very efficient.  Think about an igloo cooler.  The better ones use only 1"to  1-1/2" of urethane and they will keep ice for 7 days.  Some of the best hot water heaters use 2" of urethane and they will lose less than 1 degree per hour and that is with 140-160 degree water and a 60 degree ambient.
Urethane also adds structural strength that open cells and fiberglass do not and it forms its own vapor barrier.
This all said, The "R" factor should be thrown out when it comes to insulating.  It is very misleading and does not reflect true performance. It was a specific test  made and created and by the fiberglas insulation industry to sell their product.  It's day has come and gone.
Another bonus is that if you happen to get rained on while you are doing your roof project which is likely, the polyurethane will shed the water nicely.  I wouldn't say the same for the open cell :(
scsmith42
Bob, thanks for the additional info.  My foam insulation guy stopped by yesterday, and recommended that I use 2 x 6's instead of 2 x 4's, and that he fill 5" of the 5-1/2" cavity up with foam.  His point was that a narrower air gap between the decking and the foam promoted faster air flow, which increased efficiency.
I concur re the closed cell, and will discuss this further with him.
Most likely the insulation will be a little bit overkill... but the additional cost for the 2 x 6's is only a few hundred dollars.
Now the really good news is that.....  my insulation guy just bought some additional land, and would like to get it cleared.  It was clear cut about 7 years ago, he needs to get the stumps and brush removed.  Since I have a D8 with a root rake, we're talking trade   8)
And.... my roofer may be purchasing some land and would like a small pond dug on the land.  We're talking trade too!   8)   8)
I looked into metal roofing (all of my other farm buildings have it), but based upon the design of the house I think that a shingle that resembles a wooden shake would provide the best overall appearance.
frwinks
Quote from: Thehardway on October 31, 2011, 10:53:44 AM
Is there VB under the R19insulation?  Be careful not to create a double VB sandwich where the r19 insulation has no chance of drying out  ;)
shinnlinger
If you look at my gallery I insulated me roof with a semi load of polyiso(5k but I sold 1/3rd of it and insulated my walls as well.).  SIPS are just too much $.
Dave
Shinnlinger
Holmes
   I think Thehardway is right on with his recommendation. It could be the best trade off you ever make. The urethane foam will save you money almost every day of the year.  Holmes
Think like a farmer.
scsmith42
Quote from: frwinks on October 31, 2011, 03:30:52 PM
Good advice.  I'm not sure re the VB, but there may not be as the roof leak came through the ceiling.  A portion of the house has an attic; I'll see if I can crawl up there and look above the wall at the end of the cathedral ceiling to look for a VB.
I'm presuming that if/when we add the spray foam on top of the existing roof, we will want to block off the existing soffit and gable vents, and only use a new vent between the spray foam and the new sheathing?
oklalogdog
Well here's my 2 cents worth.  I built a rustic home in 1980 and used jumbo cedar shakes for shingles.  I floored my attic and of course filled it with junk.  To make the long story short I had to go into the attic numerous times to put stuff or get stuff.  During the summer the attic was warm but never unbearably hot.  Finally after 20 years the shingles were ruined in a devastating hail storm and the insurance adjuster talked me into replacing them with asphalt shingles.
That summer I went into the attic and it felt like the fires of Hell.  I had some old computer equipment up there with rubber feet and the rubber had melted.  Our utility bills skyrocketed and the A/C ran constantly just to keep up.  No telling how much the shakes saved me in utility bills over the 20 year span.  I am building my own home again now and I will definitely used the cedar shakes and plan to cut my own.  This was one of those lessons you find out the hard way I guess.
Amateurs built the Ark - Professionals built the Titanic
TK 2000, TK 1220, Belsaw M14, John Deere 7610 with loader, Ford 9N.
scsmith42
Quote from: oklalogdog on November 15, 2011, 07:57:30 PM
That's great info to know -thx.
Jim_Rogers
At the recent eastern conference of the TF Guild, I heard a talk by a speaker about proper building methods.
One comment that he made was that the heat in the attic during the summer months is directly proportional to the color of the asphalt shingles.
Black or dark makes it hot, white or light makes it cooler.
Jim Rogers
oklalogdog
Yeah the light colored shingles making it cooler just makes sense.  Problem is I just don't like the looks of light colored asphalt shingles.  I guess I will go with the shakes and they will surely last my lifetime.  The next owners can do what they want.
Stephen1
here is my 2cents worth, A lot windows as mentioned before are not very efficient. As has been discovered radiant heating in the floor is the warmest and most efficient with your type of ceilings, ie cathedral. maybe you should look at changing the heating method. Radiant heat stays close to the floor and does not migrate to the peak to be released by the windows. A lot of work will go into  new and heavier roof, not sure if you have a snow load to worry about there.
Stephen
Stephen
I think warm heat rises, whether radiant or not ;).
Put some fans at the peak to gently push the heat down.
Stephen1
yes, warm heat rises but because it is radiant, not convection fan forced warm air, it acts differently, it only heats what it radiates onto, thus the warmth stays with about 30-40 inches from the floor. it is an interesting topic, but maybe for another time.
AvT
Quote from: scsmith42 on October 27, 2011, 08:22:03 PM
I did somthing similar to my house a couple of years ago but I ripped off the decking before adding insulation because there was an air space between the insulation and the decking.  huge job but no point in installing another layer of insulation with a space between it and the old stuff.  make sure you do it right so condensation is dealt with or you could have a nightmare situation.. i don't know about your area but here up north it can rain in your house when the frozen condensation melts with the sun shining outside.  here the layers MUST be inside vapor barrier then insulation then a vented air space then decking and then shingles.  the air space must be well vented too with no dead air spaces or you can have a horrible soggy moldy mess up there IMHO
Wannabe sawyer, Cord King M1820 firewood processor Palax KS35 Ergo firewood Processor, 5403 John Deere, Bunch of other farm equipment,   LT70 Remote Woodmizer.  All good things but the best things in life are free.. If you don't believe me.. hold your breath for 2 minutes
Stephen1
scsmith42
Quote from: Stephen1 on November 17, 2011, 11:16:25 AM
Stephen
Stephen, there is minimal snow load here in central North Carolina.  I concur about radiant heating; I installed it when I built my shop and it is truly the most comfortable way to go.
My utilities costs are more associated with air conditioning as opposed to heating, due to our local weather patterns.
Stephen1
Not much snow there...just once in a while to make you realize there is a winter. :D
Thehardway
Radiant heats hard objects and bodies, but has little effect on air. Convection heats air but not bodies. This is radiant is more comfortable.  It keeps your feet and body warm but your head cool so it helps you stay cool headed even in the hottest situation :D
Scott, what kind of floors do you have?  Floors and masonry walls can soak up a lot of daytime solar radiation through the windows and take a long time to cool down.  If this is your situation, adding insulation to the roof will actually make your home hotter and more difficult to cool as the re-radiation has nowhere to escape to.  I have seen this in few cases where people improved insulation and actually saw a rise in their AC bills.  If this is your situation, reflective films on the windows combined with hydronic radiant/convection cooling is the most efficient way to cool things down.  You can forget using conventional air/air based cooling systems in these superheating situations.  You will never win the battle with the sun without using water.  If you have a pond or body of water handy or can do your own excavation work and have some available acreage, geothermal with a water/water/air exchange could cut your ac and heating bills by over 75%.
I have high ceilings in my house as well. I am just finishing off the drywall in my house this week.  I have 22' ceilings in the in the great room.  There is a 5'X6' window and a 6'X8' glass door with southern exposure in this room.  I am maintaining 60-65 degree temps day and night right now with no heat or cooling in the house.  The roof is 8" EPS sips over timbers with mill finish galvalume.  I have radiant heat in the concrete floors but no need to turn it on as the solar radiation absorption is more than adequate to maintain comfort.  I have found that the most comfortable indoor air temp at head height is 62.  Suprisingly there is little difference in air temps between floor and ceiling at 22'.
Large overhangs at the gable help limit summer heat gain but I will be circulating cold water through the floors in the summer to solve heat issues and using it to pre-heat well water for domestic hot water use. Don;t know if this would work in your situation.
scsmith42
Bob, the floors upstairs and downstairs are heart pine wood over a plywood subfloor.  The walls are sheetrock.  There is minimal window exposure on the south side of the house, but a huge roof expanse.  The north and east outer walls are pretty much sheltered by trees.
I have a 3-1/2 acre pond under construction about 400' away from the house, and am planning to recirculate water from the deep end (22' deep) to within 100' of the house, so some type of geothermal cooling would be a good possibility.  I'm not sure that I could gain much benefit from heating though, w/o drilling wells.
Most of the house has a cathedral ceiling, but above my bedroom there is an attic space.  Temps at the top of the bedroom in the summer time are usually well above 90 degrees, which is why I'm pretty sure that increased roof insulation will benefit.
Thehardway
Good. Just wanted to make sure! Wood floors will hold some heat but nothing like masonry or tile.  Sheetrock likewise if it is painted a light color.  Don't underestimate the pond for heating purposes, with 3.5 AC and 22 feet of depth you might be surprised what it would do.  There is little more required than placing a coil of pipe in the bottom of the pond and making sure it stays there and then trenching back to the house.  The actual geothermal pump itself is relatively inexpensive.
