wood mizer lt40 engine upgrade
Started by timbrr63, November 30, 2013, 10:19:05 PM
timbrr63
Hello everyone, question about upgrading the engine on my 1st generation lt40. currently it has the original 16hp kohler,(with only 318 hours!) which by the by is grossly under powered. Was seriously considering doing An engine swap. Anyone out there successfully swapped for more ponies, and with what engine?
mmartone
Me and another guy have changed to kawasaki liquid cooled v twins, mine is 22hp. Nice smooth quiet engine, available with more HP, bought mine local on CL.
Remember, I only know what you guys teach me. Lt40 Manual 22hp KAwaSaki, Husky3120 60", 56" Panther CSM, 372xp, 345xp, Stihl 041, 031, blue homelite, poulans, 340
MM
Be careful on the size of engine you put on your mill. Weight could cause a failure with the up/down system.
M.L. Morrow
812/614-1825
timbrr63
Hopefully weight will not be a major factor, as the one lung kohler is probably about the same weight as a modern twin in the 20 to 25 hp range.
RayMO
Just replaced the 24 HP Onan on my 92 lt40 HD with a 25 HP Kohler V twin with no problems and it has plenty of power to do the job.
Father & Son Logging and sawing operation .
timbrr63
Thanks Raymo, just what I wanted to hear! My lt40 was mfg. In 1983 so the retro-fit may be a little more challenging. So starts the search for a twin!
Jimmy Mc
Here is a link to a good place to buy replacement engines. I have bought from them and they are great to work with.
http://www.smallenginewarehouse.com/?gclid=CKbu69eajrsCFbQWMgodXiQAUw
Jimmy
Jimmy McIntosh, HF band mill
hunz
I have been wondering myself what a good engine size is for the woodmizers. I have been eyeing that new lt-35, but with only a 25hp engine I am a little nervous I will be disappointed with the cut quality with any decent speed in large pine and hardwoods. I assume anyone with experience with many different engine HP's could help. I also fear that the 25 HP Kohler will soon be downgraded HP wise as I received a mailer from TK explaining Kohler was altering the way they calculated HP ratings which would lower numbers. I currently saw with a 24hp Honda and wish for more......
Dream as if you'll saw forever; saw as if you'll die today.
2006 Woodmizer LT40D51RA, Husqvarna 372xp, Takeuchi TL140
timbrr63,welcome to the forum. I might of read it wrong,a 1983  mill with only 318 hours on it.   ???
timbrr63
Thanks for the welcome thecfarm! Nope you read it correctly,  my dad bought it new in83 used it very little and then sat for 25 yrs before I acquired the mill.
Is your Dad still around to enjoy the mill? What's all the lumber going to be used for?
timbrr63
Yup my pop is still with us, going strong at 80! I am a self employed cabinetmaker so, most of what I saw is kiln dried and used in the shop.as of late, ihave done several custom mantle and fireplace surround parts jobs.
Hello timbrr63, and Welcome to the Forestry Forum.   :)
timbrr63
Hello magicman! And thank you for the warm welcome! :)
ladylake
 Welcome, what part on Mn are you at.     Steve
timbrr63
Hey Steve,  I am in the chisago lakes area hour n.e. of the t.c.
mmartone
My mill is an 86 model, I think I used one of the original holes, had to drill the other 3.
pineywoods
Timbrr, I swapped the 18 hp briggs on my 95 mill for a 25 hp kawasaki. Like mm says, watch the weight. Adding a bigger motor to the up/down mechanics won't work too well, you don't have enough electrical capacity. If the up-down mechanism needs a little help, I posted a thread on adding a couple of garage door springs. No cutting or welding on the mill, drill one 1/4 inch hole.  do a search on "faster up for older woodmizers."
timbrr63
Thanks to all who took the time to respond and offer their advice. Time to "hot rod" ol' trusty the vintage lt40!   ;D
timbrr63
