3-53 injector replacement
Started by Nemologger, June 10, 2013, 10:50:43 PM
Nemologger
Found my problem...did the screwdriver test like Bushmechanic said...center injector is dead. Are these hard to change? Any thing I should know or anything to watch out for?
Clean and Sober
nk14zp
You will need to set the timing and rack.
Belsaw 36/18 duplex mill.
Belsaw 802 edger.
http://belsawsawmills.freeforums.org/
Timbercruiser
I think there is a youtube video how to do it :)
John Woodworth
To start with have you checked the compression? if ok change one injector, change them all, you will need a injector timming guage for that corrisponding injector and will need to re-adjust the valves and then set the fuel rack. Detroits are simple but can be a pain, my advice to you would be have someone with Detroit expierience help you
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026, lewis winch
mobile demensia
Quote from: Nemologger on June 10, 2013, 10:50:43 PM
Is this what was causing air in your return line?
Timberjack 230D
Mobile Dimension 127
Woodcraft 30-20a
2 Stihl 660's
and growing
