Pressure Washer
Started by cubdriver55, November 07, 2010, 08:50:20 AM
cubdriver55
Is anyone using a pressure washer to peal pine logs on a small scale? If so what type and size pressure washer are you using and where is the best place to get it?  Thanks  Steve
Ironwood
Buy a Honda engine first off, 5.5 is big enough, and get a "turbo tip" to multiply the pressure. Should work fine, a remember sometimes of the year are much better to peel than others.  Ironwood
sawguy21
Spend a little more to get a unit with a triplex pump. You will see more pressure and volume in a rebuildable unit, the cheap axial pumps are a waste of money. You will need to experiment with nozzles to get the desired results.
