CSI-Outdoors
Started by Jeff, September 28, 2008, 11:39:49 AM
From these photos, and from my posts in the past couple weeks, can you read the story using the  information these photos contain? :)
Gary_C
Is that your sister (the shooter) looking on in the background while you investigate?  ;D
Warbird
You found bigfoot? (bearfoot?)  ;D
logwalker
Should I start the Bar-B-Que????
Paul_H
Did you shoot up some ground with a 12 gauge?
Fresh bear steak at Brockenclaw Lodge.  ;D Poor little Winnie. ;)
Quote from: Gary_C on September 28, 2008, 11:57:54 AM
Yes
Quote from: Paul_H on September 28, 2008, 12:25:34 PM
Your on the right track, but no shotguns were fired.
No Bear meat to date.
Mooseherder
Your seeeester missed and the Bear peeeeeeled out leaving torn up field. ;D
I'm trying to imagine blood and guts dispersed there on the leaves.... ;D ;D
Quote from: Mooseherder on September 28, 2008, 12:54:53 PM
you're reading the evidence, but not quite correctly.  :)
Quote from: beenthere on September 28, 2008, 12:59:00 PM
Imagining is what you would have to do. :)
Rocky_J
Did you trip and fall in the soft ground, leaving behind a muddy footprint? Your camera is mighty close to the ground, you weren't standing upright when you took that picture.
:D
No falls, although my track record this week might lead you to that conclusion. The scar in the earth is in exact alignment with the window in the blind.
See here for the answer
pigman
Since I read the answer before I saw the clues here, they are real easy to figure out.  :D
Dave Shepard
pigman=efficient  ;D
Dave
ellmoe
   Without looking at the answer I say someone missed.  :'(Dirt/mud on the vegetation, but no blood.
