Why is my hydraulic contactor shorting out
Started by Lawg Dawg, January 24, 2018, 08:05:13 AM
Lawg Dawg
Only problem I've had with this mill so far..and has been doing this from the beginning..I've adjusted, tightened and sanded clean multiple times. Every couple days it starts doing it again
2018  LT 40 Wide 999cc, 2019 t595 Bobcat track loader,
John Deere 4000, 2016 F150, Husky 268, 394xp, Shindiawa 591, 2 Railroad jacks, and a comealong. Woodmaster Planer, and a Skilsaw, bunch of Phillips head screwdrivers, and a pair of pliers!
100,000 bf club member
Pro Sawyer Network
paul case
Activating hydraulics before the head stops.
That was our problem.
My mill has the command control station so we ran a hot lead through the supply track to the hydraulic pumps and did away with the contact strip.
PC
pc
pineywoods
Frozen sawdust...Are you aware there is another brush under the bottom of the frame ??
Chuck White
Good replies!
If you were sawing at night, you might see sparks when the block is on the contact strip if you're running the hydraulic system!
Come to a stop before engaging the hydraulics, and you should eliminate the problem!
Ga Mtn Man
Technically speaking, it is arcing not shorting out. franken-smiley
YellowHammer
Severe arcing caused by intermittent electrical connectors contact for me was caused by activating the hydraulics while the head was moving and bouncing.  I installed a permanent cable like others did to fix the problem and provide anywhere hydraulics.
It also looks like you are not getting even contact along the mill strip, as the marks are in the same relative place, along the bottom.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Lawg Dawg
Quote from: paul case on January 24, 2018, 08:14:41 AM
Quote from: Chuck White on January 25, 2018, 07:18:31 AM
Good replies!
PC
Quote from: YellowHammer on January 25, 2018, 09:13:00 AM
That was the problem...guess I'm in a hurry trying to get all this lumber sawed up with my new mill  :D
Pro Sawyer Network
Chuck White
Most of us have been there and done that, LD!   ;)
paul case
Even if you dont have command control you can fix it up to be live hydraulics. Live hydraulics are SWEET.
PC
pc
Lawg Dawg
Quote from: paul case on January 26, 2018, 08:51:23 AM
PC
I'm going to have to research that mod...I can see where it would be very useful! Thanks!  :)
Pro Sawyer Network
sparks
This usually happens when you either have a bad ground at the ground contact or too little spring pressure on the positive contact.
Clean the copper strip and the block real good. Move the block toward the strip until it touches. push it in another 1/8" to 3/8" to put it under spring pressure. Tighten up the mounting bolts.
To check for a bad ground on the ground block, take a volt meter and put the red lead on the ground block and the black lead on the weld rod the block is touching. Activate the hydraulics. If you read more than 1 volt you have a bad ground. Clean up the weld rod and the block and test again.
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
starmac
Some good info Sparks, I will have to store that info in this noggin of mine and hope it stays there.
POSTON WIDEHEAD
Southside
Quote from: POSTONLT40HD on January 29, 2018, 07:13:03 PM
Keep the strip clean.
Poston, you the official Sanitization Engineer Spokes Person for Vegas too? :D
White Oak Meadows
LeeB
Show us that brand new strip in a couple years.
wolf nemeth
Well,  I'm interested in continuous hydraulics!  Can someone please write  some specific information as to  wire/cable size,  routing, and  where to make the connections? thanks
If you  don't know where you're going, you'll probably end up somewhere else!
Ga Mtn Man
POSTON WIDEHEAD
Quote from: LeeB on January 30, 2018, 08:13:23 AM
That strip my friend is on my 7 year old mill. I keep em clean.  :)
YellowHammer
YellowHammerisms:
Chuck White
My powerstrip was so pitted that I pulled it off and turned it over!
If you do this, you'll need to unsolder the power lead at the front end and resolder it onto the other side!
customsawyer
It might be just me but I have never slowed down to wait for the head to come to a stop before grabbing a hyd. leaver.
www.thecustomsawyer.com
YellowHammer
Quote from: wolf nemeth on January 30, 2018, 09:57:13 AM
There are several references to it in this thread.  Several people did it before me and it was pretty easy.  I consider it the most useful modification that can be done to a mill.
YellowHammerisms:
POSTON WIDEHEAD
Quote from: YellowHammer on January 31, 2018, 09:32:01 PM
I'd like to see some pictures of the hook up.
Southside
Just run a spare set of battery cables out of the hydraulic box about 18" long, one end hooked up to the same spots on the pump and ground, on the other end put a snow plow disconnect.  Then grab a spare battery, make up a set of cables that are attached to it with a matching snow plow disconnect on the end of that one, instant live hydraulics, no lines to route and about $30 worth of parts not including the spare battery.  The plugs are polarized so you can't hook them up together wrong.  When you want to move the mill just un hook the spare battery.
So easy even a goat can do it!!
White Oak Meadows
YellowHammer
I didn't take any pictures of my hookup, but with a Command and Control station which has a caterpillar track, it was a simple matter to run a couple flexible welding wires from the engine/hydraulic battery of the head assembly under the mast, down through the cat track, and then unto the hydraulic pump box to the pump relay terminals.  This bypasses the contact strip entirely, but I didn't bother to remove mine.  Doesn't matter if the mill is running or where the head is, the hydraulics will function.
YellowHammerisms:
