Cutting Telephone Poles
Started by woodweasel, February 19, 2014, 02:16:51 PM
woodweasel
 Got a phone call today from a fellow who wants me to cut up a bunch of used telephone poles.(Not sure how much is a bunch) He's 240 miles from my location.We discussed mileage,hr. rates. hotels etc.He wants to use them for horse& cattle fences.Maybe 3-4 slices per pole.As a green sawyer I'm concerned about the hard kreosote poles & metal in them.Not sure how many I can cut in/hr.-16' long? I have an LT35 manual with deck package.He's trying to buy the poles and I'm trying to do the research as this is out of my league? Help ???
scsmith42
There are quite a few posts in the archives about milling used utility poles.  The general consensus is stay away from the creosote treated poles, but it's ok to mill redwood and cedar poles as long as you have a good metal detector.
I've used a chainsaw to cut utility poles for farm buildings, but there is no way that I would mill one on one of my sawmills.
Tom's 3638D Baker band mill
I know only what I read on here about it,don't do it. The sawdust is nasty,it stinks,REAL bad to breath in the dust. It gets on your clothes and than if you jump in your truck,it's in your truck, The smell is not good.
LittleJohn
I woudl recommend at a minimum to use a resporater of mask if you have to saw creosote; well actually I would first advise against and then mask up.  If the poles were in the country I would not be too concerned with metal other than the huge metal staples and grounding wire.  If the poles where in town, stay away with a 10' pole.
P.S. Old man used to climb poles (Electrical Lineman) for a local co-op and we always had the beck kindling wood  ;) very old air dried poles, split very nicely.
Solomon
Being 240 miles away , you're playing on his home field.
Common sense would dictate to me that he's already contacted sawyers near him and they didn't want to do it for one reason or another.   I'd say forget it, you're flirting with disaster.
Time and Money,  If you have the one, you rarely have the other.
The Path to Salvation is narrow, and the path to damnnation is wide.
Dave Shepard
I personally won't saw anything treated. I don't know about creosote, but the newer treatments are really bad news. I've heard that besides the health issues, it can be really hard on the metal of the mill. A friend of mine has an 85' power pole that is something like 3' on the big end. We were going to saw it up into 6x6 for a pole barn, but after some research, we left it where it was.
WellandportRob
   I mill them all the time.  I cut the butt end off, that is treated and mill the rest.  The best thing with them is you can see all the steel.  I have the customer remove the nails prior to my arrival.  They have all been past through a metal detector at the pole mill.  Make sure you set-up up wind.
2016 Wood-Mizer LT40HG 35 , Alaskan MKIII 60", Chev Duramax, Anderson logging trailer. Lucas DSM 23-19.
I do not saw utility poles.  I once sawed some bridge timbers.  The creosote build up on the blade was really bad.
The customer will not be getting the treated lumber that he thinks because it is difficult if not impossible to get any significant amount of preservative into the center of the pole.  When the pole is sliced open, this untreated wood is thus exposed to the elements.  But what do I know?  I only spent 32+ years in the telephone industry.
clww
This has been on here before, as Mr. Smith posted. Three words come to mind: DO NOT MILL! go_away
Many Stihl Saws-16"-60"
18-Wheeler Driver
WellandportRob
Maybe your guys poles are different than the ones we use in Canada.  All of ours are Western Red cedar and the lumber is beautiful.  I have sided many homes with this wood.
clww
Maybe. I know all the old, abandoned poles I see clearing are creosote toothpicks from stem to stern. Only thing I touch them with is an excavator.
18-Wheeler Driver
WellandportRob
On ours they only treat the end that goes in the ground.
You are exactly right WellandportRob.  There is a big difference.  Jumpbutt yours and saw them.
The OP mentioned "hard kreosote poles" which indicated that he had been contacted about sawing fully treated creosote poles.
Peter Drouin
Quote from: Solomon on February 19, 2014, 03:08:58 PM
smiley_thumbsup
      I have cut some for myself a long time ago and I will never do that again.  Mine were treated from end to end
pineywoods
Add me to the "run away" crowd. I let a neighbor talk me into quartering some. Never again. He used them for fence posts, and sure enough they promptly rotted away, everything but the outer inch or so..There is a reason the power companies will give them to you..
WellandportRob
Quote from: Magicman on February 19, 2014, 05:56:02 PM
My apologizes,  I do not cut anything that has been treated.
Claybraker
Down here, we used creosote poles, and then later they shifted to the green poles. Creosote are easier to climb, it's hard to get a spike in one of the green poles.
Both of them, the bottom 10' or so will be full of nails, staples, and whatever else some enterprising individual could find to fasten a sign with.
AdamT
I turn down a few telephone pole jobs each year, it's just not worth the hassle.
2017 Wood-Mizer LT40HDD35-RA
2011 Wood-Mizer LT40 HD
It's better to have it and not need it then it is to need it and not have it
woodweasel
Thanks fellows I believe I'll stay away from those critters! :-\b Daniel
bandmiller2
The way to do it is to leave the poles whole for fence posts then cut oak or whatever for boarding. Frank C.
POSTON WIDEHEAD
We used telephone poles back in the 70's to build a pole barn. Not sure where my Dad got all those poles from but we couldn't call Georgia for 6 weeks.
Arbor-Mill
I read some previous post about a year or so ago about sawing creasote poles and all the Do's and Dont's and decided that I would do it anyway to atleast form my own opinion.  Customer had 10-20' poles and wanted 6x6's to build a deer stand so I figured I could handle anything for 40 cuts and knock out 600 bf in an hour or so.  I set up up wind but my customer was down wind.  I figured him being a tough old farmer a little creasote wouldnt hurt him.  He actually had burn type rashes around the collar of his gloves and around the collar of his neck.  We finished the job and he actually made an ER visit due to the discomfort.  I felt bad since a little sawmill job cost him a trip to ER.  I guess my point is, you definitely have to keep others in mind as well as your well being.  Good Luck!
Red Good
Power poles and telephone poles treated the same ? Been looking at some poles that the local power company is replacing , thought it may be a good source . Used to them being cedar .
Stihl 211C saw
Massey 135 deisel tractor with a front loader
Can Am 800 max quad
2001 Chev S10 pick me up
Home made log arch
Too Big To Fail
I spent 2 days milling up some fully treated poles last fall.  I wore a tyvek suit, nitrile gloves and respirator.  It was raining, which helped keep the dust down, but after a while the exposed skin at my wrists developed a slight chemical burn.  I definitely felt like I had been poisoning myself a little bit.  Kept an eye out for trash, and only hit one nail.  I might do it again if the price was right.  Not worth it at the regular rate IMO.
NMFP
I have cut them but if I do it again, it will be for my own use and no one elses.  Its a real pain in the rear, especially with the dust, the chemical burns and the wear on the machine.
I would run and not even consider sawing them.  There are better jobs out there that have a lot less risk than what you are proposing to do.
