Close Call
Started by D._Frederick, February 18, 2010, 07:54:28 PM
D._Frederick
I was using my new zero clearance insert on my PM 66 to size a 20 X 24 piece 3/4 inch plywood. I needed to take off half a blade width and had pushed it through the saw.
I guess that I did not clear the back of the blade and the teeth caught it and threw it over the top of the saw blade. Didn't  hurt me but really scared me. It bent a section of the blade teeth and I spent an hour with a dial indicator getting the saw back to 0.005.
I alway but the guard on to prevent this from happening, but this insert is not cut out to allow the guard to fit.  It will be made to work with the guard!
fishpharmer
Glad your ok.  Stuff like that can happen in a blink.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
Warbird
Yeah, that would have scared the crap out of me.  Glad you are okay.
I got the middle finger of my left hand nibbled away from a kickback like that.  I had foolishly sawed a too-small piece of wood and it kicked.  I think I subconsciously grabbed at it and the end of my finger all of a sudden looked like a fire cracker had gone of in it.  It happened so quick... and the saw didn't even change pitch.  Boy!  I won't do that again. :-\
After I had that happen once  :o :o :o, I put a splitter in behind the blade (same spot the guard bolts on).
Keeps the piece from binding and climbing up the blade.
I'm surprised you could bend the teeth and blade back straight (or close).
LeeB
If you did indeed bend the teeth back I would give serious thought to trashing the blade any way. Flying iron is dangerous. Some of the teeth may be damaged enough to launch.
D._Frederick
No teeth were bent, the blade itself was/is sprung by one of the slots cut into it for vibration or what ever.  I got it close to having it straighten out, but getting the last 20% would take to much time. There are much better blades now being made.
CHARLIE
This boy doesn't stand behind any board I'm cutting.
Charlie
4x4American
Today I had a bit of a close call...I had a cant on the mill and I went in front of the head to measure where the pith was and I didn't realize it but I had the drum switch in forward and the debarker was spinning.  The debarker alarm is unplugged due to multiple noise complaints on portable jobs and from neighbors, and I didn't realize it was spinning.  I stood up and back a bit and the debarker blade nicked me in the back ever so slightly.  It didn't break skin that I know but I felt it and it could have been alot worse.  Could have grabbed my shirt and pulled me in, could have gouged a piece out of my back...etc.  My guardian angel is real good to me!  It was definitely a friendly reminder to pay attention!  Be careful out there my friends!
Boy, back in my day..
Go buy a lottery ticket while you are at it, and take advantage of all your good luck.
Scary.  That could have been nasty.
4x4American
That's a good idea I just might go get a lottery ticket!  Never really had much luck with them though!
