I found this tree today on my property. What do I have?
Started by Kbeitz, April 05, 2018, 09:14:18 PM
Dozer_Man
This kinda looks like what we call a Cucumber tree around here. It is a type of magnolia. If it gets huge leaves on it then that is what it is. Bark looks a little different for Beech at least around my parts anyways.
Brady Crabtree
Sawmill Bottom   '15 WM Lt35HD,  WM Pro Sawyer Network, 90 Chevy C50, 04 ram cummins, Stihl 362, 2008 Bobcat T180
If it is a beech, you may have a hard time getting anything stable out of it other than small pieces. I'll bet that wood is going to be volatile as it dries, again, assuming it is Beech. It will definitely be interesting to see how it goes!
Ljohnsaw
Quote from: Jeff on April 06, 2018, 11:06:32 AMIf it is a beech, you may have a hard time getting anything stable out of it other than small pieces.
If so, you would have a life time supply of bowl blanks assuming good figure!
Kbeitz
I do know that I will be keeping the slabs at least of one side if the tree. I'm hoping it looks the same with the bark removed.
Love machine shop work
and Wood work shop work
And now a saw mill work
Babylon519
What direction does the wrinkled side face? In my neck of the woods, the southwest side of dormant hardwoods are sometimes afflicted by the freeze-thaw action when warm sun thaws the bark by day and the freezing temps at night cause splitting in the bark. The flecks in your bark might be an indication of that kind of action over the years. Haven't seen wrinkles like that though!  - Jason
Jason
1960 IH B-275 - same vintage as me!
1960 Circle Sawmill 42"
Stihl MS440 & a half-dozen other saws...
Kbeitz
Quote from: Babylon519 on April 06, 2018, 01:44:33 PM
I think you nailed it. This was on the southwest side.
terrifictimbersllc
opticsguy
Do you have a mole/gopher problem???
Personally I would wait for the tree to sprout leaves for identification.  No hurry to cut, just one of a thousand trees for you to choose. Best to think and decide the ultimate use, boards or turning blanks or?   I am only guessing but looks like the those "curls" are only on one side.
TK 1220 band mill,  1952 Ford F-2, 1925 Dodge touring, too many telescopes.
Kbeitz
Quote from: opticsguy on April 08, 2018, 11:46:53 AM
Yep.  South side only. I will wait until later in the year.  Way to busy now for any new projects.
Rhodemont
My beech trees have a similar Shar pei on the southwest side due to freeze/thaw.  Not as distorted as the one Kbeitz found but similar.
Woodmizer LT35HD    JD4720 with Norse350 winch
Stihl 362, 039, Echo CS-2511T,  CS-361P and now a CSA 300 C-O
forgeblast
Its beech with beech bark disease.  My beech have it, I need to cut a bunch out to try to save the ones with out.  The bark will crack and have a waxy white look on it, once the secondary infection takes a hold the bark will turn black.
The worse thing is that every shoot that comes up will be infected.  We were told to cut and round up the stump.
Ljohnsaw
K,
Time to make lemonade out of lemons...  Keep an eye on it just in case it is the beech bark disease and cut it before it starts to rot.  Assuming you get some nice figure out of it, promote a new market for "Shar Pei Beech" ;)  Looks to be more rare then Denim Pine! :D
Kbeitz
Quote from: ljohnsaw on April 10, 2018, 07:16:11 PM
K,
I don't think I have a problem... I cant find another tree like it in all my woods. It must be the last one.
Kbeitz
When I google beech bark disease all the pictures look like this... Not what I have...
It also says It can be observed on the trunk and limbs of the tree as woolly. I don't see that...
That's more like what I have. In fact,I was driving along on my tractor,I have a roof over me,and I looked at a smooth bark tree. I had no idea what kind of tree it was until I looked up over the edge of the roof to see the beech leaves. ::)  :o  Only one on my land,I think.
bodagocreek2
I have a beech that looks pretty much like that one.
forgeblast
That picture with the cracks is the secondary infection, when the first one happens the white kind of waxy look is what looks like is in your one picture.  I have the waxy type and the secondary cracked bark, along with trees with no bark issues.
Beech bark disease - Wikipedia
http://msue.anr.msu.edu/uploads/files/e2746.pdf management
Kbeitz
Beech Bark disease is pretty wide spread up here, but I have never witnessed it to manifest itself to look like kbeitz's tree. My opinion would be that is not what it is simply because of never seeing a diseased tree that looked like it.
mike_belben
Whatever it is someone fed it too many  twizzlers.
Praise The Lord
47sawdust
I only feed twizzlers to my horse and my grandsons.
Mick
Kbeitz
I will keep everyone updated... It might be awhile because I got projects stacked up to the door.
I did not need it but I just bought a International 350 with a loader and new tires for $300.00 I need to get it home and check out what wrong with the steering. The person I got it from said the steering box broke. It's a very nice looking tractor. Looks like a very busy year for me. So when I catch up I will saw this tree and see what we have.
moodnacreek
My first fork lift was a IH 350 U turned around. I got it free because the steering box broke and they lost half the parts. Had to put a manual box on it as I could not find a power one. Years after I found a bad power box and made one good one with what I had. The other problem was starters, I broke several while I had this tractor. Other than that it was a tough, powerful, even fast machine.   On the beech I would wait until fall to cut it down [ as with any tree for lumber when you have a choice.
YoungStump
Quote from: Kbeitz on April 12, 2018, 07:43:35 AM
So will the wood under the bark have waves or not?
Yes it will, it looks like beech to me I've sawed some that looked like that and it had a very nice curly grain but it all went into pallets.
Echo Enterprises 45HD2 production series band mill, Cook's Edger, sawing mostly pallet cants, rr ties, and grade lumber.
