Is there tension in that log?
Started by BBTom, March 22, 2006, 07:54:38 AM
BBTom
I was sawing some nice Hickory yesterday, and was trying to make nice wide 12" cuts, per customer orders,  when this happened.
There was no warning, or checks to speak of, I was halfway through the cut when it went POP.  Needless to say the rest of the boards off this log where from the narrow side .
2001 LT40HDD42RA with lubemizer, debarker, laser, accuset. Retired, but building a new shop and home in Missouri.
Bibbyman
I've had whole logs do that on the first cut.
The one I remember most was small walnut that already had a crack starting.  I started making an opening face on the side 90 deg from the crack when it just busted open like a ripe watermellon. :o
Sawing since '94
GF
That looks like a hackberry I was cutting the other day.
broker farmer
I had that happen on a sycamore log this winter.  Sure did make my jaws get tight!
Happens on walnut all the time...course the only boards that split are the 12" or wider FAS boards. ???
highpockets
I am just glad to see that someone else experiences the things I do.   I thought it was me.
Louisiana Country boy
homemade mill, 20 h.p. Honda & 4 h.p. for hydraulics.  8 hydraulic circuits, loads, clamps, rotates, etc.
jgoodhart
Nope, you left out all the tension :D
jpgreen
Quote from: highpockets on March 22, 2006, 05:37:57 PM
That's just because mostly some of the time it may have been..  :D
