STIHL M-Tronic™ engine management system
Started by jargo432, April 04, 2014, 10:53:55 PM
jargo432
Has anyone had any problems with the STIHL M-Tronic™ engine management system.
Jack of all trades.
Andyshine77
Quote from: jargo432 on April 04, 2014, 10:53:55 PM
Very very few issue. The two I know of were on ported saws, and a simple adjustment resolved the problem.
Andre.
sablatnic
I have had three to give problems, one fuelled with water, one with chain oil, and one with diesel. After a cleaning they all three ran again without problems!
missedbass
If the old school 261 has limiter caps on the carb adjustment screws  that some members remove to richen it up, how does the m-tronic come set from the factory? Is it programmed to be set on the lean side and how can you make adjustments?
Stihl ms271
Fiskars x27
Reddog
Was just talking to my dealer about this the other day.
He said he couldn't remember the last time one needed a fix or adjustment for a problem. They are quite impressed with the M-Tronic.
missedbass, the same way any open loop fuel throttle body system works.
The throttle position sensor (TPS), tells the computer chip what rpm you want. The computer then uses the crank sensor to adjust the mixture to match that rpm.
Not sure how many other inputs the mtronic uses in its micro processor.
missedbass
Thanks, was just wondering if the saw could run too lean with the m-tronic
Stihl ms271
Fiskars x27
Reddog
The consensus from saw builders so far seems to be no. They can adjust to run a ported saw rich enough.
No personal experience though, so YMMV.
Andyshine77
Quote from: Reddog on April 05, 2014, 09:06:20 AM
No TPS sensor on the Stihl Mtronic saws. It's a simple feedback system that looks for max rpm under load. Too lean you loose rpm, too rich you lose rpm. The Husky's have a TPS sensor. Most if not all the issues Husky has had are carb problems, not AT issues.
Andre.
Reddog
Quote from: Andyshine77 on April 05, 2014, 12:17:14 PM
Different info than I was told, but I trust you more than my source.  ;)
