A day cutting wood
Started by Peter Drouin, May 01, 2012, 08:49:55 AM
paul case
WDH and customsawyer.
If you built a sawmill shed it would not be like my chicken house.
PC
pc
Peter Drouin
Cutting some W Pine today, Some logs are just nice.
With no knots, That's a 12"x12"x16'6"
Outher logs had some 1'x12"x8'x6".
Have a few more to do, and stick some lumber before Friday when the snow comes.
It's a pain then blocking and lumber disappears in the snow.
:christmas:
A&P saw Mill LLC.
License NH softwood grader.
Some of the best white pine that I have seen.
69bronco
White Pine don't come no prettier than that!
Bruno of NH
78NHTFY
Not naughty at all, that's nice!  Peter, if that's for your own stock, do you keep separate and sell as premium product $?
If you have time, you win....
Jjoness4
Quote from: Peter Drouin on December 03, 2017, 05:52:23 PM
Nice day today, and got a late start,
Use my laser level and cut off the tops of the posts. I had some 4"x12"x24' and 2"x12"24' lumber laying around and used that.
I put some grease on the bigger lag bolts,
I didn't have a 32' timber around so I cut a R Oak from out in my woods.
The cat has a tilt on the body and forks.
Makes it easy to move the timbers sideways,
Can put the timber where ever I want it.
Bad pix, But started down the back side.
Should have been done today, But, at 63 I'm not as fast as I used to be. :D :D ;D
At 68 I'm not fast, I'm half fast :)
2017 LT40HDD35 , Kubota 4701, Ford 3000, Stihl Farmboss
Peter Drouin
78NHTFY, I try to sell it, But, No one want's it at $1.50 to $2.00  BF. I have a pallet full I set to one side.
Maybe if I kiln dry it. I only make 5/600 bf of o knot stuff a year out of all the pine I cut.
But i'm not sawing for it, The customers I have are looking for #2 com. So I just hammer out 1" lumber in Pine.
:christmas:
A&P saw Mill LLC.
Peter Drouin
½ fast, Jjoness4,  :D :D :D :D
A&P saw Mill LLC.
Chuck White
Quote from: Jjoness4 on December 21, 2017, 08:47:17 PM
Now, say that quickly three times!   ;D
newoodguy78
Not without ending up in the woodshed you wouldn't  :D
Darrel
I have a grandson (I love him dearly) who at this stage in his life is "half fast".  He's 13.
1992 LT40HD
hersnsh#590
RE: Post # 2277.  A Northeast Get Together?  A secret?
TK 1600, small sugaring operation, a bench full of J'reds, a tired ford 1710, new to us JD 5065e, 2 Honda 4 whlrs, a Can-Am 580 on tracks, and a very understanding wife.
paul case
pc
Peter Drouin
Logs in the snow, I was hoping he would come yesterday when the sun was out.
More work now, had to pile them.
A&P saw Mill LLC.
YellowHammer
So much for global warming. ::)
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
DPatton
Peter,
Them logs may be hard to find tomorrow, with the snow thats headded you way tonight. :)
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
D & S Sawmill Services
Peter Drouin
The cat WILL find them. :D
A&P saw Mill LLC.
Be careful.  We don't want to lose you in the glaciers.
Sixacresand
I will be milling some pine or sweet gum today to get some 3/4 X 8's for vertical siding and doors for a yard building.  If I go with the gum,  I will need to nail it ASAP to minimize warping. And as it dries, the gaps between the boards will be wider, but that is not an issue.
John,
Don't take your eye off that sweetgum or turn your back on it  :D.
POSTON WIDEHEAD
Quote from: WDH on January 05, 2018, 05:23:04 PM
John,
If you do turn your back it will come around and look you in the eye.  :D
