Best tools for log furniture
Started by True North, September 05, 2010, 08:36:17 PM
True North
I am looking at tool kits for log furniture and was wondering what the best is for getting started.  What sizes would you need to do beds, tables, chairs, etc.  I'd like to start as economically as possible. Any suggestions?
woodbowl
I just bought the multi cutter with 4 different sizes from logtenoncutters.com . So far they work well. I was told from the seller that a 2" tenon is good for a bed, not that a 1 1/2" can't be used, but 2" is best. There are others out there. I'm interested in the router setup as well. What kind of tool kits have you been looking at?
Full time custom sawing at the customers site since 1995.  WoodMizer LT40 Super Hyd.
True North
I have looked at both the router setup and the cutters that go on a drill. Not sure which is better.
2" and a 3/4" Forstner bit, drill motor, a hatchet, a couple chisels, a good handsaw, some rope for use as clamps and tourniquets and maybe a drawknife.  That's all I used for my last two projects.
Oh, and a sawmill can come in handy too.
low_48
I have the single cutter, tenon cutters from Lee Valley. I don't have the large sizes, but use a 3/4" for chairs. It works really well. It will even cut a tenon on a flat board if you saw it so the tenon area is square. You can use that for making arms for rocking chairs.
http://www.leevalley.com/us/wood/page.aspx?c=&cat=1,180,42288&p=45539
barbender
That bed is sharp Jeff. One of my buddies built a bunch of log furniture using just hole saws, forstner bits, and a band saw for the tenons. The tenons look neat that way, faceted like you had drawknifed them.
