Boiled Bowls
Started by metalspinner, June 07, 2010, 02:48:48 PM
metalspinner
A while back, Jim King posted this article link on boiling bowls...
http://www.exoticwoodworld.com/boilingwood2.htm
This weekend, I decided to give the technique a go.  So I hit the slab pile and pulled out some walnut.  I cut the slabs into bowl blank sizes and waxed the ends.  I sealed them because I knew I wouldn't have time to turn and boil them all.  They were then thrown into this pallet...
After rough turning, they were thrown into the boiling cauldron. Here's the action shot... :D
According to the instructions, they should boil for 1 hour per inch of wall thickness.  Here they are after the boiling. They range in size from 5" to 10"  in diameter and 2"-3" thick.
Here is the largest of the group. It is about 13" and 4" deep.
After they dry for three days under cover, they will be transferred to paper bags to complete the drying. :)
jdtuttle
Can't wait to see how they turn out.
jim
Have a great day
I saw the Title and thought that is was about some funky Northern food  :).
pineywoods
Quote from: WDH on June 08, 2010, 08:46:40 AM
Me too, we think alike..
metalspinner
The walnut and cherry stock is still in the pot if you guys would like me to send you a couple of gallons.  It might liven up your next soup a bit. :D
Lud
If you boil it down , you might have the makings of a brown dye for light wood or ladies into weaving or other fiber arts. 8)
Gary_C
Or flavoring for grits.  ;D ;D
There you go, Gary!  Pretty soon, you will be eatin' grits bareback  :D :D.
Gary_C
Could I just go bareback and forgo the grits?  ;D
CHARLIE
I haven't tried the boiling process yet but I've used the process where you soak the bowl blank in a detergent solution and had good luck with it.  I didn't have any splitting but the wood is still moving, so the finished bowl will go a little out of round.
Charlie
Bro. Noble
Charlie,
I don't know how you treated that red oak that you used to turn those inside out ornaments for me,  but it must have worked.  I was showing a couple of them to Jake and Lorraine when they visited recently and they looked like you turned them yesterday 8) 8) 8)
CHARLIE
Brother Noble, I'm glad you are enjoying those and especially because they came from your special tree.  I didn't do anything special to that wood.  Just sanded super smooth and applied shellac. I think I waxed them too.
Charlie
