Proud new owner of a FB M14 Photo's Add
Started by Charles135, May 26, 2012, 05:55:25 PM
Charles135
I just went and disassymbled my new Foley Belsaw M14.  I was located about 2 hours from my house.  The owner was super friendly and hospitable.  We took the mill apart and loaded it up (with only one injury, a smished finger, but a mill is not really yours until you bleed on it).  I am headed home now or I would post pictures.  I will get them posted later tonight or tomorrow.
I want to thank all you guys for your info as that helped me make my decision.  Oh, and whoever said a M14 was portable has a different definition of portable than I do!!!!
One question for you'll: I have a J.D. 4039 power unit wig a clutched Rockwell pto with a 4 inch wide 8 inch diameter pully.  What is the best way to hook it to the mill instead of the pto shaft? As the power unit spins in the wrong direction.  Any photos of your conversion would be really appreciated.
Charlie
I got all the pieces unloaded and spread out.  I had to stop due to a 6 years olds Bday party.
More to come later!
Charlie
Foley Belsaw M-14, JD MT, Massey Harris 44, F-30 Farmall, A JD, 3203 JD, 5300 JD, JD 4039 Power Unit
Serving the Thin Blue Line Since 1998
hackberry jake
Congrats on the new mill, the sawdust bug is like a drug addiction, the more you do, the more you want. I would maybe run a v-belt set-up so you could turn the tractor the way it needed to spin.
Charlie,you can twist the belts if their long enough ether "V" or flat.By twist I meen top of one pulley to the bottom of the outher.If the power unit has 4" wide pulley for flat belt it isn't really enough,probibly 6" would be minimum.If its setup for "V" belts  put on as many as you can.Your right every mill demands its pound of flesh. Frank C.
hardtailjohn
Charles, it IS a good feeling to have it all loaded up and headed home, isn't it!  Congrats on the mill! Can't wait to see pictures.
John
I'm so far behind, I think I'm ahead!
Congrats on the mill. Let us know when the sawdust is flying.
PC-Urban-Sawyer
Charlie,
Don't make a habit of bleeding on that mill. A couple of drops is good for a lifetime.
Herb
fishpharmer
Congrats on the M14.  Looks very clean.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
cutterboy
A sawmill is very important and so is a child's birthday. I hope you enjoy them both. Take care of that finger..... they're not surposed to be flat.  ;D
To underestimate old men and old machines is the folly of youth. Frank C.
paul case
That looks about like the one I had. I Sure like the metal base,  it makes set up a lot easier. Mine was set up with only a pto shaft on the outside end, but I think speeding the blade up a bit with belts would work a little better.
If i had found the support of the FF I would probably still be sawing with that old m-14. PC
pc
Cutting Edge
Quote from: PC-Urban-Sawyer on May 27, 2012, 05:37:29 PM
Charlie,
Herb
I sure hope that is the goin' rate for chainsaws also....if so I'm sure most of us are paid up/ahead: Outta the RED and operating in the black.
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
- Sharpening Services
- Portable/Custom Milling and Slabbing
- On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blades
Ph- (304) 878-3343
Charles135
Thanks guys,
I think one bloody finger should about do me for a while.
I hope to get her all put together by the end of the week and I add some more photos.
Charlie
apm
I've got the original setup and operation manual for the M14. If Timberking can't send you one I'd be glad to mail it to you to copy.
Greg
Timberking 1600 now
Charles135
Greg,
I will check with Timberking first and let you know.  Thanks.
Charlie
