Whatcha Sawin' 2019 ???
Started by Magicman, March 08, 2019, 08:46:24 AM
goose63
N.A.D.A. its 15 below wind chill :snowball:
goose
thank you to all the vets
Grass Farmer
2 weeks ago I got around to milling some pignut hickory for a friend.  In total we got about 500bf in about 4 hours.  Used the WM Turbo 747 045 for the first time.  I was able to cut faster than with the Kasco 4° I used for the first two logs.
They also seemed to stay sharper longer on my mill....until I raised the backstops up into the blade after the last cut  :'(.  My mill has the handle for the travel next to the handle to raise and backstops.  I wasn't thinking and went to pull the head back and raised the backstops up instead.  Before that I was honestly impressed with how fast I could cut that hickory.  I don't know if it will dry flat, but it came off the mill pretty flat.
richhiway
Hope that tractor is something easy. Maybe it was an axle?
Woodmizer LT 40
New Holland 35 hp tractor
Stihl Chainsaws
Ford 340 Backhoe
YellowHammer
Quote from: jb616 on November 12, 2019, 11:24:01 AM
"Man, I can't believe nobody added to this thread for nearly a week"  probably chasing deer!  the Rut is on! fudd-smiley
We have been sawing and selling here at Hobby Hardwood.  I milled about 4 thousand bdft of 4/4 walnut this week, among other stuff, trying to beat the cold that showed up today.
It was some pretty nice walnut, most was from veneer grade logs, with some decent boards.
Here's the results of a few hours of sawing, a couple stacks of boards.
On Saturday, we had a pretty busy day, lots of customers on every rack.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Brad_bb
Quote from: YellowHammer on November 12, 2019, 05:52:17 PM
Now that looks like a destination if I'm in your neck of the woods on a Saturday.
mtoo747
Didn't saw today....with the rain and cold that we had, but i sawed a nice cherry log yesterday. Had to trim the crotch a little to fit my mill. Ended up 19" wide 7' long.
Had some very nice figure!
Got five 2 1/2" slabs and a couple lesser ones.
I plan to make some coffee tables in the future.
I pictured this Walnut "Log" back in September.  Whatcha Sawin' 2019 ??? in Sawmills and Milling
Well, it got delivered today.  Not enough to travel for but it still needed sawing.
Some short blocks.....
And some really short blocks.  Here I used my trailer and log loading ramps to keep it from falling through the sawmill bed and to stretch across the side supports.
The customer got a nice load of mostly 9/4 slabs.
One stick looked like this and this is not a crotch.  It was midway between limbs.  Crazy stuff looked like marble.
Anyway, I buttoned the sawmill up when I finished sawing until after my knee surgery recovery.
Brad_bb
MM, yup, you  never give up on Walnut.  Even if it looks rotten, there's still some good wood there.  You shouldn't necessarily throw away hollow logs either.  They make great table bases for glass top tables.  Google "hollow log table base" and click images.  Lots of ideas there like this one:
I have a cherry log that is similar only wider and more spectacular.  I even like the epoxy pours in a hollow log and then back lit by led's.  Wishing you a speedy recovery.  I'm sure I'll have to get mine done in a couple years.
Bruno of NH
That's some beautiful stuff  :)
tule peak timber
WV Sawmiller
   Thought about posting in the cold weather thread but actually it warmed up a little above freezing this afternoon so I decided to go saw a log to get out a customer order for 4-8' long 4X4 posts. We discussed cutting them a little oversized since they are green so agreed on 4.5X4.5. We will see how much they actually shrink but they turned out well. Was the butt log. I sawed the side lumber up into 2X4, 4/4 and even trimmed out about a dozen 3/8" Lathe/project strips for making crates and such. It really sawed real nice which is the norm with tulip poplar.
 Decent log, typical flare for butt log
 4 nice posts and about 33 bf of side lumber including the 3/8"X 2" strips on the side. Not a lot of waste that way. A couple of trim pieces about 1/2" thick which are always handy for various projects around the place.
Ljohnsaw
Quote from: WV Sawmiller on November 15, 2019, 03:37:16 PM4 nice posts and about 33 bf of side lumber including the 3/8"X 2" strips on the side.
Just curious, what did you do with the pith?  Was it split between the 4x4s?  Wondering how the tulip poplar behaves.
John Sawicky
WV Sawmiller
In this case I sawed my posts FOH and sawed the pith into 4/4 boards and a couple of 2X4s. I could probably have sawed a 4.5" cant out of the middle and centered the pith in one and got one on each side FOH but I'd still have had to gotten my 4th post out of the side so in this case I took off a board or two on each side till I got about a 10" face then set my Simple set to drop 4-5/8" and got my posts that way avoiding the pith. I left about a 4" pith that way and just sawed into stock - 2x4s and 4/4 boards.
Southside
If they didn't turn into a banana coming off the mill they should be fine is my experience with Tulip.
White Oak Meadows
SawyerTed
I've had a couple of good days sawing.  Yesterday was 2x6 and 2x8 white oak for dump truck sideboards. Today was Walnut and cherry.  Nothing special except three beautiful cherry logs. Some of the cherry was 10" wide 12' long with very little sapwood.
 In
richhiway
Cut some nice wide pine slabs. One of them will be for my wife. She needs a table for her Nascar autographed cars.
Woodmizer LT 40
Stihl Chainsaws
Ford 340 Backhoe
Darrel
Sawed a buggy blue pine log for a neighbor on Friday. And a hairy woodpecker came down to help. Wouldn't even get off the log when I rolled it. When the saw head got too close, he flew up and over the saw as it went by and landed on the back side.
And as you can see, the blade took a dive because I hit a rock in spite of the fact that the bark was loose and just fell off the log.
1992 LT40HD
Woodpeckers have to make a living too.
WV Sawmiller
   Thanks for the woodpecker post. I'd love to have seen him hopping over the blade as it was sawing. I guess he wanted to be a mill mascot or something. i was grinding deer on the front porch and a redbellied woodpecker lit 2 posts away from me and started singing. We have been having big piliated woodpeckers in the yard and on my logs and slab pile lately.
terrifictimbersllc
Make sure you give him the slabs for free.
Stephen1
I have a couple of woodpeckers at my yard also, they really like the pine with the grubs
Crossroads
Sorry, nothing to share off the sawmill. Still been working a lot of hours and getting work done on the apartment. The good news is that I have the apartment done enough to move in. The 5th wheel froze solid a couple weeks ago, so I had to push the issue and get moved in. I still have some sheet rock to hang, but we're insulated and warm 😁
Here's the latest progress video
https://youtu.be/jjO4QGiJxp8
SawyerTed
White oak beams.  Lots of white oak beams.  The customer rides his tractor and there's only one helper.  But I quoted the job at an hourly rate.  It's his nickel....
This is part of the first whack.  We had already cut 5 logs.  There are three more whacks.  I'll be back for a couple more days.
