Finished Some More Bowls
Started by Left Coast Chris, April 13, 2013, 03:42:44 PM
Left Coast Chris
Latest batch of bowls.  I have been really impressed with how Silver Maple works and finishes.   The two figured natural maple bowls are taken from block wood at the butt flare with compression figure.  Also tried a few Redwood bowls.  Very soft and takes alot of heavy sanding to get the tearout to finish.   Having fun with the lathe.
Closer view of the Silver maple natural edge bowls:
Spalted larger Silver Maple Bowl
Large Redwood Bowl
Home built cantilever head, 24 HP honda mill, Case 580D, MF 135 and one Squirel Dog Jack Russel Mix -- Crickett
Tree Feller
Those are nice. I really like those NE Silver Maple bowls.
Cody
Logmaster LM-1 Sawmill
Kioti CK 30 w/ FEL
Stihl MS-290 Chainsaw
48" Logrite Cant Hook
Mooseherder
Nice looking bowls. :)
You inspired me to turn one this evening.
clww
Many Stihl Saws-16"-60"
18-Wheeler Driver
Left Coast Chris
Just curious, what finish will you be using Mooseherder?
Ive become partial to the Deft Danish Oil Natural finish with Watco wax polish to finish it off for the Maple anyway.
wheelinguy
Makes me want to put a lathe out in the shop and start turning.  Nice work!
Mooseherder
The last few bowls I've turned have been finished with walnut oil.
I soak an old toothbrush in a cap full of oil and press it on the bowl as its turning.  Works good and smells good. :)
The bowl I turned tonight was from a branch I cut off a Mahogany tree today.
The tree is about 18 years old.  I did a lot of tree trimming this morning and also prepared some Australian Pine that has been in my pond after breaking off the tree.  It looks like some beautiful stuff and some of the hardest wood you can find.  My turning tools are horrible and I am in turning bowls on a spindle lathe.  Life is kinda rough some times. :D
I have most of the outside if the bowl done except for the sanding.  I was having a hard time digging out the inside of the bowl and it was getting dark.
I moved the lathe outside to my cook shack last week and roll it out onto the grass when turning then put it back with a cover and back under the shack when done.  It wasn't being used much in the garage because of the mess.
I prepared quite a few pieces for turning that should keep me busy for the summer evenings.
mesquite buckeye
pasbuild
I really like the Maple ones, were they turned green or dried?
If it can't be nailed or glued then screw it
Left Coast Chris
Mooseherder, turning outside sounds really therapudic..... Im envious.     I tried the Mahoneys walnut oil on a black walnut bowl awhile back and it turned very dark then did not want to harden.  Since you mentioned you had luck with it I might try it again.  With the oils I have to remind myself to wipe off any excess on each coat and warmer weather helps too.  I think the walnut I used was root burl and it was a bit porus and took in alot of oil.   It ended up almost black and had to dry for several months.
Pasbuild, the maple was turned from four year old blocks so they were almost dry.   Ive done well dry or wet with Silver Maple but if wet then I turn to an inch thick then put wadded news paper inside and place it in a paper bag to dry over several months.   Final turning takes out the warpage.   I do stay away from limb wood due to the stresses and heart center unless it is a special case.
Fun stuff and relatives really go for them at Christmas. :)
Dodgy Loner
Those are awesome! You really have a good eye for form. Anyone can make a bowl, but there aren't many people who can make them look that good :)
Left Coast Chris
Glad you guys liked seeing them.   The test of course as to form, appearance etc is if people will buy them.   I have traded for other wood but so far cannot bring myself to sell them because of the attachment and just like seeing the wood.  Maybe someday....when I retire...    fishin-smiley
Lud
Nice bowls, Chris.  Turn lots of bowls and give them away.  Always sign and date them.   I've  never met a woman who doesn't like wooden bowls! 8)
justallan1
Busy Beaver Lumber
very nice work. A true craftsman at work :)
Woodmizer LT-10 10hp
6 x 10 dump trailer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
GeorgeK
George Kalbfleisch
Woodmizer LT40, twin blade edger, Bobcat A300, Kubota L48 and yes several logrites!
Axe Handle Hound
You do some nice work Chris.  I think you'd be pretty successful selling those. As I mentioned in the thread about the rustic shelf I built, my friend who commissioned the shelf has a number of different woodturnings that he's purchased.  He doesn't know anything about them other than they're wood and he really likes the way they look.  Your bowls would certainly look right at home with the rest of his collection and I can tell you that he paid a pretty penny for the ones he has.
mesquite buckeye
Definitely high end work. I have a friend who does this type of work in mesquite. He does it first because he loves it, second because he makes a marginal living doing it. The bad economy dropped his sales by 2/3. Maybe things are better where you are. Just remember, if you sell to craft/art outlets, you will get about half of retail, maybe a little less. They have bills to pay too. Good luck. The work will sell. ;D
Left Coast Chris
Thanks for the encouraging feed back guys.  I do enjoy making them along with the display of the special piece of wood.   Awhile back I was asked to put some in a local gallery but normally they want 40% or even 50% of the selling price to run the gallery.   Makes sense.  Im thinking a better option might be to talk my daughter into a booth at a high end craft fair and pay her to attend  the booth.  Since the booth costs a bit, I need a higher inventory.    An internet site is also a possibility but Im a little concerned people would buy then try to return after handling it since they cannot physically examine prior to buying.
All food for thought.  :P   --thanks--
CHARLIE
Very nice bowls and well finished. I really like the natural edged maple bowls, but all of them are done very well. Two thumbs up to ya!
Charlie
I have never turned, but I can admire and appreciate high quality and beautiful work.  As Charlie just said;   smiley_thumbsup smiley_thumbsup
Left Coast Chris
Thanks guys.  Wish it was the Fall/Winter again which is the main time I work in the shop so I could do some more turning.  It gets so hot here in the northern part of the Sacramento valley I do not look forward to Summer.    My issue is no insulation in the ceiling of the shop so my window air conditioner can't cool too well.   Im strongly thinking of buying some 5 R-value 4x8 foam with foil face sheets to glue to the under side of the sheathing between the TJI joists.   About $500 at Home Depot.   Then I would be back in business.
