Butternut Surprise
Started by 78NHTFY, September 18, 2018, 09:50:43 PM
78NHTFY
Had some nice dry home-grown Butternut I milled up for kitchen cabinet crown molding.  Put on two coats of Tung Oil and the figure, which was pretty much invisible beforehand, just popped out.  I was surprised, to say the least.  Should'a been used for furniture, but hopefully can be seem in my kitchen, with the right light.  All the best, Rob.
If you have time, you win....
Ljohnsaw
John Sawicky
Downstream
Butternut always surprises me in a good way.  Wish I could find more it.  That molding should stand out in the kitchen.
EZ Boardwalk Jr,  Split Second Kinetic logsplitter, Granberg Alaskan Chainsaw Mill, Stihl 660 and 211, Logrite 60" cant hook, Dixie 32 Tongs
PA_Walnut
Looks just like quartered sycamore.
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Peterson Dedicated Wide Slabber
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Northland 800 Kiln
Bruno of NH
Looks like cherry. I've never seen it in butternut and I have worked with some for projects.
Nice figure. :)
78NHTFY
So here is where it ended up.......  This project is why I haven't been sawing near as much as I've wanted to.  It will be two years in Dec.  The face frames/doors/drawers I had custom made of maple from my drawings.  The wife is ready for this to be done!  On this side, the toe kicks, subway tile, undermount lights, new dishwasher still to go.  All the best, Rob.
You sure that ain't cherry? ;) I do know that butternut can have a pinkish hue, but it's the grain that looks cherry-like. It's a nice crown moulding. :)
FLPINERAT
Wintergreen Mountain
1920 Ford 4x4 tractor, forks & bucket. 2010 36" Turner Mills band mill. Cat-Claw blade sharpener. Cat-Claw Dual Tooth Setter. Cat D3 crawler dozer. Cat 215c excavator, Ford L9000 dump truck. Gardner Denver 190 portable air compressor. KatoLight 40Kw trailer mounted gen set. Baker M412 4-head planer.
I think cherry and butternut are both semi-diffuse porous. :)
low_48
Huh, I thought butternut and walnut were nearly identical. Never seen a ray fleck in walnut. I'd have sworn that was cherry.  None of these pictures show medullary rays with some really nice end grain enlargements. No rays, no fleck. http://hobbithouseinc.com/personal/woodpics/butternut.htm
petefrom bearswamp
Sure is prettier than my butternut.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
georgecoolguy
Looks very nicely finished... What did you use for clear coat/top coat?
78NHTFY
Thanks georgecoolguy.  Just two coats of Tung Oil.  Fairly hard wood so didn't want it to look too shiny.  All the best Rob.
Peter Drouin
A very nice job you are doing there. smiley_thumbsup
A&P saw Mill LLC.
License NH softwood grader.
78NHTFY
Thanks Peter.  Amazing what you can get done if it takes you TWO YEARS TO DO IT!!! ;D.  All the best, Rob.
