Building a mill.. FIRST LOG WAS A SUCCESS!!
Started by jwh f-100, January 12, 2018, 01:31:50 PM
Ljohnsaw
Not nearly as elegant but you could use a welded eye screw-eye, a cable thimble and cable clamps.  Making your own, you could go with a slightly lighter weight cable and then not have to worry about running out of room on the winch spool.
John Sawicky
jwh f-100
When I fastened my cable to the spool I went around it one extra time. Probably didn't need to. While it's not really an issue i will probably remove that extra cable..  With that little extra removed it won't double up..
Why buy it when you can build it.
jwh f-100
 More done today.. Good progress on the guard. On the bad side my first blade is defective and the casters I bought won't work. Looking for suggestions on casters..
Not really related but I built this a couple weeks ago with spare junk. It works great!
jwh f-100
More progress today.. Nothing worthy of photos really. I was just cutting steel for my log bed...
At this rate I'll be making boards after a few more days work!   8)
I'm trying to decide if I should mount it on a trailer or not..  smiley_whacko
Kwill
I mounted mine on a trailer so it would be portable and easier to move around. Eventually I may build a shed to put it in and pour a concrete slab to put it on. Although it is nice it being at knee level instead of down at foot level. Don't have to bend down to remove boards.
Built my own log arch
built my own bandsaw sawmill
Built my own atv log arch.
Built my own FEL grapple
jwh f-100
The big drawback for me is needing to lift the log up on the trailer..
Kwill
Build a log arch big enough to set them on it.
starmac
If I was going to mount one stationary, it would be above knee height too. The low ones just looks like they will make an old man out of a young man way too quick.
jwh f-100
Good point on the height guys..  It has me contemplating a push bar on the saw head rather than the "chassis".. Hmmmm
jwh f-100
Wow. Been over a month since I've posted updates.
I'm almost ready to saw logs. I need to fine tune the blade an put my front cover in place. Once it seems to be operating as it should I'll have to add many finishing touches..
jwh f-100
I milled my first log yesterday.. Everything went smooth and straight!!
Cant wait to wrap up the minor thing and bang out some lumber!!
btulloh
HM126
ssn vet
Just got through this entire thread.... lot's of good info.  Thanks to all that posted.
One question for the OP.
How come you put your pillow blocks on top of the cross rails?   Seems like most I've seen are on the bottom and that would give you some more clearance above the blade.
Inquiring minds want to know  :)
jwh f-100
Quote from: ssn vet on August 23, 2019, 04:34:04 PM
Just a rookie mistake I guess. LOL  :)
