230 timberjack throttle adjustment
Started by lynde37avery, October 20, 2014, 07:08:17 PM
lynde37avery
353 detroit motor. The pedal barely does anything. I have to use the hand throttle. Any tips on adjusting the pedal linkage?
Detroit WHAT?
deerguy
 lynde37avery,
Not sure if it's of any help, but on my ol' TJ330 with a 353, I had the same problem. My issue wasn't so much the linkage as it was the hinge pin at the bottom of the pedal. It was so badly worn that the pedal had free movement in every direction but one that would rev it up !! I fixed the hinge and then only had to do minor adjustments with the linkage.
Good luck !!
Deerguy
I knew she was a keeper when she told me to buy the old skidder !!!!!
David-L
Is this on the franklin or the Jack. If on the jack make sure the hand throttle and the foot throttle linkage is not bound up. They are connected together near the left side of the tranny which you can see. The spring should be able to put the foot throttle back in place. There is adjustment where the foot throttle linkage goes through the firewall. Give me your address and I have an extra manual for these 200 series and I will get it to you. I would follow that linkage from the pedal.
                                                            David l
lynde37avery
Yea timmyjack 230. Ok check ur msg box davidl.
Detroit WHAT?
