Ideal backstop height
Started by Rougespear, December 15, 2015, 01:00:06 PM
Rougespear
Hi all, I'm deciding how high to make my backstops above the saw bunks.  Looks to me that WM's and Cook's are no more than 12-14" high... is this high enough to secure the larger 32+" logs, as well as turn them without climbing the backstops?  I ask, because my inclination would say make the backstops to be above the centerline of the largest log, so approximately 16" for a 32" log.  Any thoughts on design here?
Custom built Cook's-style hydraulic bandmill.
sawguy21
Below the blade. ;D Sorry, couldn't resist that.
york
Hi,
16 inch is too high-my old TH mill was about 16 in. and i cut them down to 12 in.
You need to angle the tops to about 30 deg. so log will not climb..
Albert
Chuck White
My blade will clear when set at 11¼" when the logstops are all the way up!
Ga Mtn Man
Generally taller is better...if you can make them stout enough to handle the extra torque at the base and you have somewhere to put the extra length when lowered.  The backstops on the LT-40 are 11" which isn't tall enough for really large logs.
Dave Shepard
I don't often have any issues with the standard WM height, but I do have the rollers on top. If they are not tall enough, you can keep a couple pieces of pipe just large enough to slip over the backstops when you find an ornery one.
drobertson
12" standard wmz back stops have managed fine for me on capacity size logs for the mill.   I guess there are many options a fellow can pursue,  I know the rollers on the tops helps in my opinion.
sandsawmill14
on our timberking b20 they are about 16-17" i will try to remember to measure them tomorrow  :)
kelLOGg
I have sleeves to slip over 2 of my backstops for large logs but I use them only is the log is irregular and is prone to catch on the top of the backstops. I don't have rollers on mine but I think that would help a lot.
Bob
ladylake
It sure cant hurt to have high one so long as they're  sturdy enough and you have clearance.  Steve
fishfighter
On my manual mill, I have two sets. The short ones are about 6" and the long ones are about 16". Some times logs will climb the long ones. Longer = better.
Ljohnsaw
For my mill, I made two sets - one set is about 18" and another around 30" - but about 4" is used below the bunks to mount/lock in place.  They are manual and sometimes raising them to roll a log or cant is annoying, so I'm thinking a slip-on set of roller is my next upgrade.
John Sawicky
Brucer
Quote from: Chuck White on December 15, 2015, 02:26:11 PM
On my manual LT40 I could clear them at a height of 11-1/8". On my hydraulic LT40 I can comfortably clear them a 11". The message is, check the clearance on your own mill (with the blade not turning).
I've had 36" logs on my mill with 11" high stops -- no problem. I've had 44" logs that were split in two with a chainsaw -- no problem when standing on edge.
Sometimes lower stops are an advantage when you have a really big log on the mill. You can have the log overhanging the stops and gain a little clearance on the idle side blade guide. That lets you drop the blade down 1/2" to 1" lower.
Bruce    LT40HDG28 bandsaw
Rougespear
Thanks all for the overwhelming responses... typical class act on the FF!  I think I'll make em 12" high as that seems to be the standard (there must be a reason WM does it so no need to reinvent the wheel.  I also like those folks' idea of slipping a pipe over the top to make them longer.  I am using 2x2 material for the squaring arms, and a piece of receiver hitch tube could nicely slide over!
Thanks and merry christmas all.
pineywoods
Just be sure to make them adjustable. They WILL get bent out of square with the bunks. I see them bent on woodmizers all the time, and they are 1X2 solid steel.
Rougespear
They are adjustable to be square with the bunks (modeled after Cooks' design).  Good point though piney... I was considering backing up the 2x2 backstop with some 1/4" x 2" flat bar on edge to help with the abuse, is that advisable?
Percy
Quote from: Rougespear on December 15, 2015, 01:00:06 PM
If you have a choice in your design, IMO Id make them go up and down vertically as opposed to the "lay down" style of the LT30-40. Having previously owned an LT40 and now an LT70, its been my experience that the vertical backstoips make life easer.
Quote from: Rougespear on December 17, 2015, 10:56:58 AM
Sometimes, something has to bend or give.  So consider what your extra flat bar is fastened to, and give thought to it bending instead of the backstop. Always need a weak spot that is easy to fix.
isawlogs
 I would concider having them lower then 12", I like being able to cut down to 12's "with the mill with out having to worry about cutting the backstops... Just saying what I like  ;)
   Marcel
Brucer
That was my thought, too, Marcel. It's nice to have a nice, round number that you know is safe to cut at, no matter where the stops are.
sandsawmill14
look for a video on the timberking b20 and watch how the back stops work as percy said up straight up and down is MUCH better than the pivot i have 3 mills 1 lays down from from end to end(parallel)  to the mill (homemade), 1 from side to side perpendicular to the mill (s&w 125) and the tk b20 is straight up and down and is by far the best design they can be any height from 0" up to 16-17" and anywhere in between. this would probably be the most expensive to build but after running all 3 designs it is by far the best :)
xlogger
Why would you want low back stops? Unless you have the type that fold down and it makes it hard to do. On my TK they go straight up and down so its no problem lowering them to the height you need.
John S
We all call them backstops but WM refers to them as "side supports", (just the retired teacher in me).
2018 LT40HDG38 Wide
isawlogs
 For one, I have had my mill since 93' and have had to use extentions on it , maybe three times, and only because the log was iregular in shape and it kept riding up the backstops. That being said, I do use my clamp and claw turner to turn bigger logs, I turn the log till it gets lifting some, bring the clamp under it and as I bring the turner down, back out the clamp. The log rolls some and then with the turner, I am usually good to bring it where needed.
  I like having the backstops under 12" to be able to take that cut and not worry about cutting them. Not having higher backstops to work with I don't see what I am missing. Also putting on extention pipes when needed, for little use of them that I do need, is an option that is available and works well too.
   Marcel
Quote from: John S on December 18, 2015, 09:08:07 AMWe all call them backstops but WM refers to them as "side supports"
No, not everyone.  My sawmill has four sides; a front where the tongue/controls are, a back where the taillight is, and two sides. One is the loader side, and the other is the log support side which has the "side supports".
Marty Parsons and I had a PM discussion about this subject a couple of weeks ago and he promised and I quote,
QuoteSide supports. Side Supports. Side Supports.
