what type of birch would you say this is
Started by Quebecnewf, February 26, 2009, 05:48:57 PM
Quebecnewf
Here are a couple of pics of our birch. What type does it look like to you. Ignore the chainsaw stuck in the large spruce that leaned the wrong way
Quebecnewf
dsgsr
Northlander band mill
Kubota M59 TLB
Takeuchi TB175 Excavator
'08 Ford 550 dump
'87 International Dump
2015 Miller 325 Trailblazer Welder/Gen
Reddog
Looks like what we call Paper birch or White birch. One in the same.
dsgsr, I have never heard of gray birch. What is the range/area that it grows?
Oh and that saw doesn't look stuck, you were just giving it a break. ;)
dsgsr
Kubota M59 TLB
'08 Ford 550 dump
rick f
664 clark skidder
1- 562 husky
1- 254xp husky
1 - 268xp husky
5040 kubota farm tractor
chainspinrunner
It looks like Gray birch or  Paper birch they are very similar to each other. Both birch's have similar characteristics anywho. Good luck!! Is it in a forest or yard?
Grose
ontariologger
gunman63
Maineloggerkid
It is the color of grey birch, but the peeling bark makes me say that it is white.
JD 540D cable skidder, and 2 huskies- just right.
Loggers- Saving the world from the wrath of trees!
cheyenne
White birch thats collecting social security so it's getting grey.....Cheyenne
Home of the white buffalo
chevytaHOE5674
Quebecnewf
If one had two boards one from paper/white birch and one from yellow birch. Could you tell which board came from which tree
Quebecnewf
Gary_C
You should be able to tell by weight comparison as white birch is lighter (lower specific gravity) than yellow birch.
The tree in the pictures is white/paper birch.
Quebecnewf
Is there that much difference in the SG from one to the other.
The reason I ask this about the birch is a few years ago I had an order of yellow birch deals 2" KD come for a woodworker customer of mine and at the same time he also bought from me some of our local birch that I had KD in my kiln and he told me you could not tell the two apart and he used both woods in the project and I saw the finished product and there was no difference.
Is this normal or are they supposed to be different
Quebecnewf
I had some white birch that looked like that.But mine was good size,over 2 feet easy and old,70-80 years and red rotted bad.This stuff had some real rough looking bark,like grey birch and around the limbs was almost black and rough.The grey birch that I have here does not get much bigger than 6 inches.Probaly because by that time trees have grown up around it and smothered it out.
Rick Alger
A forester told me that white birch will sometimes hybridize with grey. The tree he showed me looked like yours. He didn't mention yellow birch, but I suppose it might hybridize too.
chainspinrunner
Can you take pictures of the buds or leaves that might be on the ground dried up? If so this is an easier identifier.
Grose
Clark
Quote from: Rick Alger on February 27, 2009, 08:11:32 AM
I don't know a lick about grey birch, so it could hybridize with paper birch for all I know.  Yellow birch is triploid, that is, it has 3X the number of normal chromosomes (or 3 sets of chromosome...something like that).  I am unaware that paper birch has that same condition which would, from this feeble minded and poorly educated geneticists stand point, make hybridization very unlikely.
Clark
PS - Looks like paper birch but I don't know grey birch.
SAF Certified Forester
From what I've confirmed, cannot separate the wood of white birch and yellow birch, even microscopically. And even density is not a sure thing, as there can be overlap in the range of each.
Need the trees for ID. Once in lumber, can be either/or.
PAFaller
There are some differences between white birch and yellow birch in certain geographic regions. For instance, my first gig out of college was at a sawmill scaling logs. THis was in south central NH. White birch cut in southern NH had a wormy look to it, even when it was healthy, not so much holes but just an off type of grain, and was far lighter in weight. Same white birch tree grown in the White Mountain national forest, a far colder environment, could be sawn and piled with yellow birch and you could not tell the difference. You could also sell the heartwood as the infamous red birch...talk bout creative marketing of a tree that doesnt actually exist.
It ain't easy...
bberry
On the coast of Maine we have all three and the yellow has the best firewood value with gray being the least. The yellow has SLIGHTLY denser,darker,reddish wood. The gray is much inferior in all respects. I have never seen any of the 3 types that show any signs of hybridizing. The yellow has a wintergreen smell and taste, golden bark and is common but sparsely populated. The photos are of white birch.
Colton
Definitely white birch, grey birch doesn't peel like that.
White/paper birch. No way its Yellow birch.
Quebecnewf
In our region we are not supposed to get yellow birch. I have seen White Birch in Quebec City and the tree looks nothing like our so called white birch. The trees in Quebec city have white bark. I think we have yellow birch or a hybird of yellow and white.
Quebecnewf
maybe somone has a photo of white birch
FTD
Looks like Gray Birch to me.  White Birch bark typically doesn't peel so fine.  Also could be Balm of Gilead.
