Vapor problem with Zip wall?
Started by shinnlinger, February 27, 2013, 06:59:52 PM
shinnlinger
Hi,
I hung conventional 2x4/zip wall walls on my timber frame a few years ago and time and money has prevented me from getting it done.  Today I went to plug away on the upstairs (I live downstairs) but when I pulled the insulation back to drill holes for wiring I noticed that a significant amount of moisture had been trapped between the inner surface of the zip wall and the pink stuff
Concerning to say the least.  The plan is to put 2 layers of 2 inch polyisocyinate foam continuously over the studs(4 inches) on the inside, foaming/not stacking the seams , strapping it and then hang drywall off the strapping.  That will create a significant vapor barrier but trapping moisture that makes it thru in the stud portion is obviously not a good thing.
I have had a fan blowing on it for several hours and it is drying out and the problem will be lessened significantly when the space gets heated and the interior foam is installed but I wonder if I should put a collar on a drill bit and drill the the zip wall as many places as a can to allow moisture to escape.  I have B&B hung on the outside.
I have an email into JM Huber.  This might just be what happens when you wait two years to finish an unheated space in winter while you live below it and moist air condenses on a cold wall, but interested in your suggestions/solutions before I bury it all back up.
Thanks.
Dave
Shinnlinger
Jay C. White Cloud
Hi Dave,
I am so terribly sorry!!!
I see this all the time.  It's what is in many walls, and if I started writing and rewriting all the problems with pink insulation, house wrap, and general bad building practices, I would be writing into the wee hours of the night.
In short, don't use pink insulation, don't use house warp, (good old shingle laid tar paper still is the best and cheaper,) and make sure you have a cold roof tied into a breathing wall system to create a air current around the thermal envelope of your structure.
Regards,
jay
"To posses an open mind, is to hold a key to many doors, and the ability to created doors where there were none before."
"When it is all said and done, they will have said they did it themselves."-teams response under a good leader.
shinnlinger
I wonder if I put a piece  of strapping in the middle of each bay vertically to create an airspace under the pink and drill a small hole at intervals right next to the strapping  so the wall can breathe a bit would be a good idea?  Zip wall is supposed to breathe!  But to be fair how can a piece  of painted OSB breathe?
Dave
Shinnlinger
Rooster
Is there a air space between the back of the board and batten siding and the osb sheathing?
"We talk about creating millions of "shovel ready" jobs, for a society that doesn't really encourage anybody to pick up a shovel."
Mike Rowe
"Old barns are a reminder of when I was young,
       and new barns are a reminder that I am not so young."
                          Rooster
Jay C. White Cloud
QuoteZip wall is supposed to breathe!  But to be fair how can a piece  of painted OSB breathe?
So is Tyvek my friend, and in the lab it appears to most of the time, but not in the real world.  If I was called in on a job like yours, I would recommend a "cold roof," tied into a "breathing wall,"  and spray foam the wall to the point of your desired R factor, that way the "dew point" lands inside a waterproof insulative layer.
Regards,
jay
shinnlinger
Hi,
Rooster,
The B&B is applied right to the zip wall but the 1x10s are cupped slightly so I bet they breathe pretty good.
Jay,
If I put two layers of 2 inch foam (4 inches polyiso) on the inside of the studs, do you think I put the dew point in the foam?  I have a cold roof but drilling up my eve plates into it might create more problems than I have now but I have 5 ft knee walls so that certainly is a possibility.  Do you think a 1 inch hole for each stud bay up into the roof would work?  I could set a stop collar on an auger bit and probably pull that off with out much fuss actually.  My roof is zip roof topped with 3 two inch panels of polyiso with  a 2 and a 1/4 inch gap (2x + strapping) between the top of my foam and the steel roof
To make the best of a bad situation, I am thinking of putting attic vent panels on the walls to create an air space wherever I can.
http://www.google.com/url?sa=i&rct=j&q=soffit++baffle&source=images&cd=&cad=rja&docid=_t5u4wlBS0HTPM&tbnid=ok-pw8pRVYyVUM:&ved=&url=http%3A%2F%2Fhome.comcast.net%2F~atticpros%2Fventilation.html&ei=YrQuUcrKJqOX0QHn74HACg&bvm=bv.42965579,d.dmQ&psig=AFQjCNEO7WHKViJoE8HGrCYF5rqlQjsxew&ust=1362101731211725
Shinnlinger
Rooster
So just that I'm clear...this is a interior humidity/moisture/condensation problem, not a 'trapping moisture behing the siding" problem...correct?
Mike Rowe
                          Rooster
Jay C. White Cloud
Hi Dave,
I feel worse than before for you.  I just don't know what to tell you that is optimistic.  I won't build without a breathing wall and cold roof interface, forming good convective flows around the thermal envelope.  When I saw that product hit the market I had concerns imminently.  If I was seeing this problem with regular OSB, what was this stuff going to do.  I really don't want to say this, but If was working for a client with this problem, I would be talking to the manufacture about some form of a settlement and/or fix on their dime, not my clients.  If you go with all foam insulation, I think you will be fine.  I would install a breathing wall as time and money allows.  I don't think you have a true cold roof form your description, I could be wrong.  A cold roof vents over the thermal envelope and out the ridge and gable.  Most of them have from 2" to 4"  (2"x4" on edge or flat,)  of space sleeper rafters on top of the insulation with no obstructions to the ridge.  It's about the same for the walls.  Keep us up to speed on everything, and good luck.
Regards,
jay
shinnlinger
Well I have a call in to HUber, but I do have a cold roof like you describe, the channels  runs from eve to peak, and I really think I can tap it pretty easily.  How big should I make the holes?
I kick myself on the zip wall as I knew deep down that painting OSB green doesn't suddenly make it permeable but they swore it allows 2-3 perms.  Whatever that is....
Shinnlinger
shinnlinger
and Rooster, you are correct, my problem is on the inside....
Shinnlinger
Aikenback
make sure you have a suitably sealed vapour barrier on the inside (warm, moist side), and everything will be fine. look for any signs of mold on the inside face of the osb and maybe spray it with a mild bleach solution or some  mold killing product where its necessary. it will dry out and stay dry with a proper vapour barrier.
no whining.
shinnlinger
Aikenback,
I think you re right (what other choice do I have?) but if it only takes me a day to drill holes and $150 to buy and shove attic vent between the pink and the sheething I figure I should give it a go.
It will be interesting to hear what HUber has to say....
Jay,
You have any pics or diagrams of how you connect your breathing walls with your cold roofs?  It might give me some ideas.
thanks.
Dave
Shinnlinger
Jay C. White Cloud
Aikenback,
I'm sorry, I have to really challenge you on the concept of internal vapor barriers, all the research and field testing has shown they just don't work.  Moisture still gets behind them.  The worse cases of mold and pest issues I have seen are in structures, (commercial and residential,) with interior vapor barriers.  If you are using them and they are working that is great, but the only way to really tell, is tear out sample wall after five to ten years and look.  Most contractors that I know that still use them, don't do that, so there really isn't a way for them to know if they don't have mold and moisture in the thermal envelope.
Regards,
jay
Jay C. White Cloud
Dave,
I don't currently but I doing a project right now and I will make sure to take pictures for you.  Also, they can work in concert with each other or be independent.  What is important, is the chimney effect, bottom to top with a good draft.
Regards,
jay
shinnlinger
Is your current project in Vermont?  Would it be better if I saw it in person?
Dave
Shinnlinger
Jay C. White Cloud
Absolutely, it would be best in about two weeks, if all goes well on other jobs, but if you want to come by sooner I would love to help and talk through things with you if you would like.  Just let me know.
I built my home in '67-68 with good poly vapor barrier on the warm side, then fiberglass insulation, southern pine plywood sheathing (sure didn't want to get that wet), and cedar board/batten siding. After 30+ years while adding a great room, these walls were opened up and there was no sign of moisture on the sheathing.
There are some good arguments that the vapor barrier inside isn't the best in the south where the reverse happens with cold air in the home from AC cooling causing condensation on the inside cold walls.
I agree that the mold on the osb is not a good thing, and looks to be a tough one to correct. Likely wasn't good to have the insulation in place and not a good vapor barrier on the warm side of that. But that is in the past. Need to look forward at this point.
tyb525
All I can add is, I've seen more rot, mold,and termite problems in homes built in the last 50 years, than the homes that are 75+ years old. One of the major differences seems to be plastic vapor barriers and house wrap.
Jay C. White Cloud
As you could tell I began to fall silent.  When folks find an opposite conclusion to what seems to be facts about a technique or method, I take a moment to ponder, but I must concur on those occasions that it is observed other wise, I too have seen more rot, mold, and pest damage in modern homes than I have in vintage.  Oddly enough the older the architecture, the sounder of condition in many cases.  I guess that is why I still tend to build as traditionally as I possibly.  I find that most modern marvels aren't as marvels when really looked at closely.  Just an observation.
jueston
as i have said in other posts, for a while i dealt with situations like these full time, i worked almost exclusivly on stucco homes and homes with eifs, and it was my experiance that the problem was always breathing on the outside not the vapor barrier on the inside. that being said i think there i a big difference between MN and down south where there is more AC and not as much heat. but overall the idea is relativly simple, trapped water causes destruction. it has to escape in or out, and the design should plan for one or both.
as bad as what your looking at seems, i have seen far worse, i have worked on a few mansions where entire sides of the house were destroyed, every single stud so far gone that it had to be replaced or sistered with another stud, top and bottom plates with huge holes in them, headers that were nothing but dust. sometimes i would just look at the house with my engineering mind and be boggled how it is still standing. so looking at your pic my thought was that its good the framing still looks really good, which is a great sign, cutting out rotten and moldy framing and replacing it, is dirty horrible work, as i'm sure you know after pulling out that moldy pink insulation.
but it sounds like you have some good ideas rolling around in this thread and a good plan being formed, you just got to give the moisture someplace to go.
good luck.
Jim_Rogers
The only problem I see with drilling a hole to let the moist vapor up into the roof would be that it could also let a fire spread up there too....
I don't know if that would ever happen, or not.
Jim Rogers
shinnlinger
Its a valid point Jim, but I'm in a tough place on this.   Do I not vent because of the chance of fire and pretty much guarantee my walls rotting/mold issues , or do I take a chance and vent? Once flame gets in my walls, holes or not, Im afraid Im going to loose the house due to my rural location and volunteer FD so I think I need to take the chance.
I am still wondering how big I should make the holes....
Shinnlinger
shinnlinger
Jueston,
How would you mitigate this problem?  What solutions did you come up with?
Dave
Shinnlinger
jueston
Well with stucco/eifs the problem is a little more straight forward, the point of water penetration into the wall is usually pretty easy to find. And once we found it, we repaired all the damaged studs and sheathing and another company came through and reapplied the stucco or eifs. The truth is, we really dealt with a symptom and never dealt with the disease, which was breathability. But we always used tar paper on the outside and not tyvek and the stucco or eifs being put on had some kind of drain system built in. but I wouldn't be surprised if in 10 years some of those houses will have problems again, I wasn't the GC while doing this, I worked for a GC who took his orders from the insurance company.
Your situation is less clear to me, I don't really understand if the problem is water coming in from the outside or condensing from the inside or both?
If its condensation, then it seems to me that foam will solve the problem, it will act as a moisture barrier and it won't trap the moisture like the fiberglass does. Since the condensation will be greatly diminished the small amount of moisture in the walls might be able to escape with the current level of breathability. Which would mean no need for drilling holes. But I can't give you any guarantees, just my opinion...
If I were to drill holes, I would go with many half inch holes instead of a few big holes, the reason is that I work on older houses and they tend to have a slight gap between the 1X's on the outside of the studs, a series of small holes would simulate these gaps between each board. Maybe 2 big holes would be just as good, I don't know.
frwinks
Encountered the same thing with my father's house a couple of years ago.  Typical warm interior air meets cold sheathing scenario.  His house was built in the 60-70's, pink insulation, poorly detailed VB, chipboard sheathing, vinyl siding.  Decades of freeze-thaw cycles and the house is still standing, with sheathing in tact.  It dries out every spring/summer to both exterior and interior..a breathing wall ;D  sorta'
The best approach would be to insulate from the exterior (keep the sheathing warm enough to push the dew point out of it, for your area 2" of Polyiso will do it).  If that's not feasible, you could do what I did on his house.  Preferred cavity insulation (paper, wool, rock, anything except glass) followed by a 2" layer of foilfaced polyiso.  At .03perm/inch polyiso is a very effective WRB/VB on it's own, the foil is an added bonus.  Devil is in the details, tubes of acoustical sealant, gaskets, spray foam, etc...you really have to go OCD on that stuff ;D  People will laugh and point fingers, but the way I look at it, at the end of the day they're not paying the bills for heating and cooling or wall replacements.  The ones who have no clue about building science will laugh the hardest while they drink free coffee at the pro desk :snowball:
Top and bottom of the walls are critical to get air tight as well as all the post/beam connections.  Sheathing will still be cold, but at least you're preventing gobs of the warm interior air from hitting it and condensing on it.  Any condensation that does form on it will still be able to dry to the outside.
Is the siding attached directly to the zipwall? No rainscreen/strapping at all?
For the roof, do you mean soffit vents?  Sounds like our roofs are similar in construction.  I have more insulation and two layers of 2x4 strapping with a 3" air gap washing down the insulation envelope.  Continuous soffit venting is the only way to go IMO.  Size depends on the roof area, but it's always better to oversize the air intakes.  Mine is a 4" wide strip, venting roughly 2500sqft of roof.  Do you have a continuous ridge vent?  You will need one.
shinnlinger
Hi,  I'm still cooking up a  plan.   Huber just told me I need Kraft faced insulation.  how was I suppose to know that?
I have a bathroom that I hung rock in but haven't  taped yet.   I plan to pull a sheet and cut thru my poly ISP and see what the pink and inside of the zip look like.
Shinnlinger
Jay C. White Cloud
Fingered they would some how make it your fault...doesn't surprise me one bit, and I don't think it would have made a bit of difference, maybe even made it worse if you had used craft faced.  Can't wait to see what you find behind that poly ISP.  They are not going to own that there product doesn't work until they have several class action law suites piled up on them, by then they will have made their money and can move on to the next scam...I mean product.  Keep us up to date Dave... ;)
shinnlinger
That's the thing.   Zip wall is pretty new.  I was one of the first in my area and now I see it every where.   Most folks probably get there buildings done alot quicker than I do but have no idea that their house is rotting around them.  It's going to be ugly a few years from now!   As much as this sucks,    I'm glad I'm finding out about it while I can do something realitivly cheaply and easily.
Shinnlinger
shinnlinger
Well I hadn't taped the bathroom yet and we have lived in the house a year so I pulled some drywall, cut thru the foam and pink and fortunately I didn't find any moisture, so it appears that the foam has done a decent job as a vapor barrier.  For the first floor, I think I'm going to insert ABS tubing, random sizes of PVC and conduit I have laying  around and strapping between the zipwall and the insulation into  the stud bays from above wherever I can to create an air space.  For the second floor I will staple attic vent to keep the air movement going and then drill thru the top plates 2 or 3 2" holes per bay into the cold roof.  I will then put 2 layers of poly iso on much lie the second floor and hope for the best knowing I did what I could.  In the spring I will look at drilling in the bottom of the bays form outside and putting screen over the openings....
I looked on Huber's website and nowhere does it say to not use fiberglass insulation.  They recommend cellulose but do not prohibit the pink stuff....
Shinnlinger
Jay C. White Cloud
Hi Dave,
That must make you feel better! 8)  That's the bath room so thing's are looking up.  :)  That foam I bet did the trick.  Keep us up to speed.
jay
Brucer
Theoretically I'm supposed to have some kind of expertise in this field ??? ::).
When I built my house in 1979-1981 I used glass fibre insulation (the pink stuff) with a 6 mil vapour barrier on the inside (building code called for 4 mil at the time). Inner walls are all drywall (aka sheet rock) painted with 2 coats of enamel paint. I stretched the vapour barrier over everything ... electrical boxes, doorways, whatever. Then after the drywall was up I carefully cut out inside the openings so the plastic is actually stretched up tight around anything that penetrates the drywall.
Before doing any insulation, I also used electrical putty to seal every opening in every electrical box on the outside walls. No way for warm air to get into the walls that way.
The outside walls are 5/8" plywood, covered with good old fashioned tar paper.
I have had to penetrate various walls from time to time and I always pulled a sample of the insulation to have a look. Absolutely dry, even now after 30 years.
Keep in mind that the climate here is cool (mostly) and dry. And I don't have air conditioning.
If you seal the interior walls really well, and get obsessive about plugging openings into the interior walls, you will probably be OK in cooler regions.
I've seen a few examples where people didn't get around to finishing an interior wall after insulating it. I've pulled out soggy insulation and even had insulation frozen to the outer sheathing in winter. Looked pretty much like your case.
Bruce    LT40HDG28 bandsaw
tyb525
I've said it before and again, house wrap holds moisture in. I don't know how many times I've peeled back the housewrap to fix something, only to find rotting OSB sheathing. Housewrap doesn't "cause" moisture, but it does trap it if moisture gets under it. And in many homes, builders don't pay enough attention to making it watertight, or allow for drainage, and that's when water gets under it and can't get out.
One area is windows. They cut the housewrap at the corner of the windows and wrap it inwards, but don't seal that corner where there is now a big gap. Then they don't flash or use window seal around the nailing flange, water gets right through vinyl siding and under the housewrap.
It's a shame builders don't know or care about some of the older building methods used to allow buildings to breathe, thinking it will make the house drafty or something. In fact there is a housing edition nearby that  is being built so bad it should be a crime. Slab houses on top of topsoil, no sill seal under the bottom plate, you can feel the wind blow right through. Asphalt shingles held on with 3 staples. Most of the sheathing is 7/16" foam board, with a few sheets of OSB thrown in for minimal diagonal bracing. The HVAC systems aren't balanced, cold/hot spots all over the house.
And the sad part is, people buying them think they're getting a great spec house.
What happened to some of the old methods, and why aren't they being followed anymore? Some of them were definitely good ideas, and it seems like many of them don't take more time or money to do.
I work for a contractor, he knows "some" old methods but not many, but I'm not about to try to tell him he's doing something wrong ;) It would be interesting to strike out on my own, using more traditional methods.
shinnlinger
Well the official word from HUber is once I put the foam up everything will be A-OK and don't worry about, but they dont think it will hurt to vent it either.  So thats what Im going to do. Vent it as best I can and hope for the best.
Dave
Shinnlinger
Jay C. White Cloud
All the luck to you brother...may things go as you plan.   ;D
tyb525
What kind of foam are you going to use? Spray on?
shinnlinger
I bought a semi load of used poly iso sheets to build my roof "sips" but had enough left over to do my walls also.  2 layers over the inside face of the studs.  Should be a good vapor barrier if I can seal it to the floor and ceiling.  IN my bathroom pic you can see what I did downstairs.  Only one layer there, but same idea.
Shinnlinger
