Ten things I hate and like about winter.
Started by Bibbyman, December 24, 2005, 08:19:50 PM
Bibbyman
I hate.. >:(
10.   ... the cold, dismal weather.
9.   ... having to wear heavy coats, gloves, insulated underwear.
8.   ... to have to cut and bring in firewood.
7.   ... that every thing outside is some shade of gray.
6.   ... the short hours of sunshine – when it shines at all.
5.   ... when it's 6:30 pm and you feel like going to bed.
4.   ... that everything is hard to start and to keep running.
3.   ... scraping ice off the windshield.
2.   ... ice in my beard and mustache.
1.   ... attractive women all bundled up so they all look like Ewoks.
I like ... :)
10.   ... having no bugs!
9.   ... coming in from the cold to set by the fire.
8.   ... short work days – fewer interruptions in the evenings.
7.   ... long winter nights.
6.   ... the clean look of fresh fallen snow.
5.   ... that cold drinks stay cold until they're completely drank.
4.   ... warm soups and chilies.
3.   ... snuggling under heavy blankets in a cool bedroom.
2.   ... seeing a bald eagle soaring across the sky.
1.   ... knowing spring is only a couple of months away!
Sawing since '94
Frank_Pender
ElectricAl
Bibbman and Frank,
You guys need a nice heated SawShop ;)
At 70 degrees, no bundling required ;D
Linda and I custom saw NHLA Grade Lumber, do retail sales, and provide Kiln Services full time.
farmerdoug
We see bald eagles all the time here as there is a nest on the Ford Reservoir just a couples of miles from where I live. 8)
Farmrdoug
Doug
Truck Farmer/Greenhouse grower
2001 LT40HDD42 Super with Command Control and AccuSet, 42 hp Kubota diesel
Fargo, MI
Woodwalker
Snow???? It was 70 degrees here today, warmer tomorrow.
Just cause your head's pointed, don't mean you are sharp.
Part_Timer
Winter is a lot like pouring concrete.  It proves who your real friends are. :)
Only a real friend will help skid logs at 10 deg.
Peterson 8" ATS.
The only place success comes before work is in the dictionary.
Bibbyman
Quote from: ElectricAl on December 24, 2005, 09:14:57 PM
Bibbman and Frank,
You've got a real nice setup for sawing in bad weather - but it's missing this great view that changes with the seasons.
Sawing since '94
Frank_Pender
It was 59 degrees here, today.   We just completed a cold snap of about ten days below freezing and no moisture until the last two.
The number one thing I like about winter,more time to spend right here at my favorate forum!
Modat22
Why does everything wait to break in the winter time, why not summer?
I have wracked my brain, and can only think of one thing to recommend Winter.  I don't have to mow the grass.  I'd gladly trade that for another hour of daylight or some warm weather.
Corley5
Every outdoor task takes exactly twice as long.  If a job takes an hour when it's warm you'd better alot two when it's cold ::)  Tools or parts dropped in the snow are all but impossible to find.  Unless they are ferrous and then that requires a trip back to the shop for the magnet ::)  Just went through that ;) ;D  Tractors need tire chains to function with any efficiency, gloves never stay dry for long, backing a two cord trailer load of firewood up hill and around the corner of a house on wet snow isn't feasible or possible but the customer won't believe it til you try ;) ;D.  A piece of equipment that worked flawlessly all year will fail with the coming of cold and snow, you find out how much water there really is in your suppliers fuel >:(
IMERC
Quote from: Bibbyman on December 24, 2005, 08:19:50 PM
I hate.. >:(
So bring them inside . that'll take care of the Ewok look. thank goodness fer mood fires, fire wood, whip cream and coco. long nights to take it all in.
DOW said this morning that 11 feet of snow has fallen in the last two weeks. ya can loose a large truck let alone some small part.
I like winter.
Who ever invented work didn't know how to fish.... Here fishy fishy....
thedeeredude
Geez, what do you guys have against the snow ;D  I love when it snows, but unfortanately, it ain't been doing much of that this year.  We got about 8" of snow total and a little here and there but thats it.  And its not a white Christmas today >:(
Daren
Snow is no good, but when it melts on top and the ground is froze 3" down it is worse. It warmed up and I have 3" of mud soup on top of frozen ground, what a mess.
Experience is something you don't get until just after you need it.
WH_Conley
I hear what yer sayin, Daren, had to hook the mill behind the tractor two weeks ago and drag it up the hill and across the neighbors farm to get it to a job. Have logs to saw at the house but can't get a truck in or out, log truck hasn't been home for two weeks, 4x4 only. Frozen mud on logs, chip for ever with an axe and still hit a chunk you missed, bye, bye blade. Snow snake bit the boy that helps me yesterday, was on the tractor with a load of sawdust on the trailer behind, taking it to his dad to bed horses with. Over the hill, no damage to him or the tractor, can't say that about the trailer.Did I mention that I hate sawing in the winter?
Bill
maple flats
I like winter. No bugs, no pollen allergies, everything looks new again, the beauty of nature, Don't get over heated, get more done per hour because no need to get a drink of water after eack cut, fewer visiters to slow things down, shorter work days and long nights to cuddle, that is the best.
Frickman
I was thinking of starting a new thread, but you all have beat me to it. How do you folks in the northern climates deal with the cold? I mean in a psycholigical way. Once I'm out in it, if it's a nice, clear day around 25, and I'm not broke down, its's not too bad. But just walking out of the house every morning when it' 10 and that cold air hitting your lungs gets to me day after day. I know winter has a purpose, and I don't want to wish my life away, but I can't wait for spring. The best thing about Christmas is that spring is only three months away.
wiam
Frickman,  When it is 10 degrees we cheer because it is not -15.
Will
ElectricAl
Ya Bib,
My view consists of concrete and OSB :-[,
and if I go outside my view is a barren farm ground. :-\
Being on top of a hill, I can see barren farm ground for miles. ;)
crtreedude
I am not allowed to mention our weather anymore- Jeff is wishing a snowstorm on us...  ::)
So, how did I end up here anyway?
Cedarman
I like it when the ground is frozen as there is no mud. I hate it when the ground if frozen as the logs are frozen too.  Hate sawing half frozen logs. I hate logs frozen to the ground.  I like unloading logs on frozen ground as they stay clean.  I hate it when the ground is not frozen, because everying is muddy. Logs are muddy, shoes are muddy, lumber gets mud on it, equipment gets mud on it.  I like it when the ground is not frozen because the logs are not frozen either. Did I mention I hate sawing frozen logs.  I hate a deep snow because it all falls off the roof at the same time making a 4 foot high snow drift that has to be moved. Oh, but walking through a nice falling snow at 3:30 PM Fri afternoon  (employees go home time), mill quiet time, is so beautiful.  Hope it all melts by Monday morning.
crtreedude
Okay - thinks I like about YOUR winter and our summer.
It pretty much stops raining here from January till about Mid May - gets just a little breezy, temperatures are just a little cooler - when I go down to the fincas, it is about 82 or so for a high instead of 86 or so.
The fishing is great too. We get lots of construction projects down this time of year. All the trees are in the ground and we don't have to clean around the trees as much. We do have to prune a lot of trees this time of year, but that isn't too bad.
What do I hate? Influx of tourist - a HUGE influx right about now.
Oh, and there are bunches of tropical fruit that are ripe now - like Mangos!
Jeff,he was warned,get going on that snowstorm for Crtreedude ;D
farmerdoug
Hey, I love mangos so hold that snowstorm as it may damage the trees. ;D  Beside if they get a snowstorm all the way down there I hate to think how cold it would be here. ::)
Farmerdoug
Doug
Fargo, MI
