Tree Farmer C4D Skidder - What to look for?
Started by coxy74, December 30, 2013, 10:49:35 AM
coxy74
Hi all.
I have a mate looking at getting a smaller skidder to do 3 blocks of pine. Hes found a tree farmer C4D for cheap. Just want to know from anyone out there what to look out for when going to have a look at, and any pit falls when using it??
Coxy74
ga jones
Simple machine. Check center section and walking beam for play. Run the winch. Drive it around tight circles make sure it doesn't jump around. That's signs of planitary issues. Try to hook cable to a tree and pull to see if the winch slips and spin all 4 tires to make sure the no spin is working. I know guys that had planitaries blow and they just remove the axle and put it back together.
380c timberjack c4 treefarmer international trucks jonsered saws. Sugi hara bars d31 komatsu 350 tj grapple
coxy74
Thanks for the reply, any motor issues or controls problems to look for?
Thanks again.
logging pete
Look closely at he planetary covers, the three pins need to be tight if it has Rockwell 68's.
