Cat 312 grey console problem
Started by rudeag, February 21, 2014, 01:40:14 PM
rudeag
Shut down last eve and everything good. This morn crank up but no audible horn and console goes dead/blank after cranking, throttle does not operate
Engine will run but not enough power to motivate. Any help would be appreciated. Thanks
ran
e tx
Autocar
It sounds like you have a electronic accelerator so I'll about bet you have a blown fuse.
Bill
rudeag
more info... the panel stays lite for 3 or 4 seconds while displaying 888 where power range is normally. I have isolated voltage to panel off the switch and it is good to panel when the panel goes blank. Anybody what 888 means?
Mainelogging94
How new of a 312, you probably have an electric governor actuator. if this is not working it would cause your machine not to idle up, and the lack of power. Im not sure what would be the cause, maybe a blown fuse like he said^.
