Band Saw Tooth Set?
Started by dgdrls, April 01, 2014, 09:49:30 PM
dgdrls
Question:
What is the "average" tooth set for a band blade??  I have read a good starting point is use the band thickness.
So if I understand on an .045 band you would have a total kerf of .18  (.09 twice)
Stems from over-thinking an example I found on recovery rates using cubic meters and % recovered that I compared  to Scribner, Int. and Doyle scale.
Thanks,
DGDrls
barbender
Usually around .018" to .025" per side, if I remember correctly. .045+.025+.025=.095, I know actual kerf is a bit more than that, though.
Chuck White
I usually set mine at .025, which comes out to .095 as stated by barbender!
If I have a lot of pine to cut, I will set them at .030 which is the same as .045 (blade thickness) + .030L + .030R = .105 kerf.
I also run between .025 and .030 sometimes you can get by with a little less if a band is cutting well in the logs your milling. Frank C.
dgdrls
Quote from: Chuck White on April 01, 2014, 11:32:56 PM
Got it,
Thanks gentlemen,
DGDrls
Chuck White
Quote from: dgdrls on April 01, 2014, 09:49:30 PM
Question:
Thanks,
DGDrls
Dan; I read your opening post again.
In your example, if you were looking for a kerf of .18,  you would have a blade thickness of .045, leaving .135 for total set, divided by 2 (left & right), so your set would be .067 each way, for a total kerf of .179.
That would be some horendous set!  :o
I do understand it was for example only.  ;)
So blade thickness + set left + set right = kerf.
barbender
Also, the actual kerf seems to be more than the measured kerf in my experience.
Bender is right, I usally figure 1/8" for band kerf, circular mills are the same always a little more than the width of the bit. Frank C.
