I hate my .075
Started by Quartlow, April 06, 2007, 10:26:36 AM
Quartlow
Seems like all I do is work on it. Sad part is I don't use it much. To darn heavy.
Last fiasco, I had to cut a pin oak at my brothers that took a lightning hit last spring.
Halfway through the back cut it goes to running like real bad the quits. It spit the compression release out.  >:(  I haven't figured out how it can get out of there.
The hole in the case is smaller than the release. It had to of broken up somehow. in the process part of it got to the flywheel and broke off half the fins.
Fortunately I found used parts. My local Stihl dealer doesn't' toss anything.  8)
The pin oak? I had to finish off with the 750 Echo. 20 inch bar and and a 50 inch tree don't mix. It was real ugly before it was all said and done.
I need to find a dependable replacement for this thing that can handle a 36 inch or so bar. Since I don't use it often, I'm considering getting a 36 for the 750 and running skip tooth chain. I bet I haven't made 40 or 50 cuts in the lat year with the .075.
Or get rid of the 750 and the .075 and by a new saw that will run a 24 inch bar with regular chain and a 36 with skip tooth.
Breezewood 24 inch mill
Have a wooderful day!!
sawguy21
The decomp valve on that tank was a common issue. Stripped tank screw threads, leaking intake gaskets, the list goes on. You would probably be happier with the MS660, a lighter,modern design. The Echo would struggle with that much bar if one is available.
TexasTimbers
Get a 372XP or better yet a 395XP and open up the muffler. The 395 with a modded muffler and 32" bar is downright scary.
sawguy21
The 395 would be a very good choice, mine  ;D, but I figgered you might want to stay with orange and white.
logger
Yup, I would get either a husky 395XP or stihl MS660 mag.  But if you like power a husky 3120XP or stihl MS880 mag, will pull your largest of bars with ease. 8) :o ;D :D ;) :)
220 Poulan            Future Saws
Stihl MS280             Jonsered CS2171
Stihl MS440 Magnum Husky 575XP
Stihl MS460 Magnum   Dolmar PS-7900
Husky 385xp            Stihl MS361  Stihl MS441 Magnum
Stihl 066 Magnum       Stihl MS660 Magnum
Quartlow
I'm not brand loyal!! As long as theres orange on it somewhere  :D I all ready have all 3 any way.
I think the 750 would pull a 36 with skip tooth. That saw runs great. It pulls the 20 with out a whimper. You can lean on it and it doesn't care.
Even the 395 xp has got to be lighter than that .075. An 880 Stihl is out. I'm not spending a over a grand on a saw.
Quartlow
Well I called my local husky shop, he has the 395XP with a 24 inch bar for $919 Baileys has it for 889.
So I figure Buy the 395 local, buy the the 372XP powerhead from Baileys. The 24 ich bar will fit it then buy a big bar from Captain for the 395.
That way I get a good deal from Baileys, and I keep my local dealer happy. I think its a win win situation
TexasTimbers
Quartlow
Quote from: kevjay on April 06, 2007, 02:50:34 PM
You are a smart man. :)
WOW!! first time thats ever happened  :D What are smoking anyway  :D  :D  :D
Tony_T
Glad you've found a good deal1! Local support can be an important asset.
I'm, a "Stihl" person, would have went with a 361/044/046  and 066. Just my 2cts!
ComputerUser
Whatcha going to do with the 075?
Al_Smith
 Those big old "bone shakers" aren't for everyone,that's for sure.If you have the mechanical knowledge and a lot of patience they are hard to beat in big wood.Then again,just how often are they really needed?
For the average saw user something in the 70 to 80 cc range would handle just about any sized requirements needed.I'm a collector and restorer and also a saw user.As a general rule it is McCulloch and Stihl.That being said just about any pro grade saw is pretty good these days.
If I were to purchase a new one,dealer support would be a deciding factor,as they all need parts from time to time.Then again,in the unlikely event I did purchase a new saw,a majority of the internet community would either think somebody stole my password or I was ill or something,ha. :D
Corley5
I had the 372/395 combo for quite awhile.  The 395 saw little use but if the HP was needed it was there  8) 8)  You'll like them  :)
Quartlow
Quote from: ComputerUser on April 07, 2007, 11:47:22 AM
It's going up for sale!! Along with the echo 750evl
logger
Quote from: Quartlow on April 07, 2007, 10:53:04 PM
There you go CU, another one. 8) :D ;) :) ;D
Quartlow
Quote from: logger on April 08, 2007, 11:54:43 AM
HE's right, get your checkbook out  :D
ComputerUser
Quote from: Quartlow on April 08, 2007, 07:12:38 PM
Oh goodness, like I need another big saw.  Out of curiosity, how much do you want for it?
TexasTimbers
Quote from: ComputerUser on April 09, 2007, 11:17:29 PM
I hate to see all these nice successive quotes go to waste ;D Instead of selling it Quart why don't you keep it for experiments and practice. that's what i am using my Stihls for these days before I do the actual mods on the Huskys. I'm going to move past thre muffler mods which are pretty straight forward and coming next is porting.
Hate to wipe out a Husky but if I make a mistake on the 024 or 025 I haven't lost much. :D
Okay that is a joke you Stihlers it is well documented I like both brands.  I just prefer Husky for big 8)
oldsaw
Quote from: Corley5 on April 07, 2007, 03:50:15 PM
Throw an 026 or a 346 in that mix and you would be set.  I'm a step above that...an 066 and a 3120.  I use the 066 where I really should have a 70cc class saw.  That's my next step.
So many trees, so little money, even less time.
Stihl 066, Husky 262, Husky 350 (warmed over), Homelite Super XL, Homelite 150A
