Quick Fix
Started by Magicman, March 16, 2015, 08:53:19 PM
Well a temporary fix anyway.
I suddenly lost my power feed.  Hit the auto clutch to disengage, and that would not work either, so I killed the engine and started looking for a kicked breaker.  Yup, the "acc" breaker was tripped.  I reset the breaker and the power feed was OK, but as soon as I engaged the auto clutch....tripped again.  I quickly determined that the auto clutch wire was grounded.  Since the wire goes through the wiring harness, etc. the quickest way to get going again was to run a temporary wire.
I laced the temporary wire along the flexible conduit.
Backed off on the conduit connector and entered the control box.
And then it was a simple matter to connect the temporary wire on each end.  Five minutes and I was sawing again.   :)
I'll trouble shoot the grounded wire when the customer's hired help is not watching.
POSTON WIDEHEAD
Better sign up for the "Loop" this year.  ;D ;D ;D ;D
Peter Drouin
Good job, Did you have all the stuff with you to fix it?
Or did the customer have the stuff.
A&P saw Mill LLC.
License NH softwood grader.
red
He is part Magic and part Mc Gyver
Lumber Grader
"It's Magic"!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I had everything to do the temporary with me which prompted me to do the quick workaround.  :)
pineywoods
Hhmmm, must be a common problem. I got bit with almost the same problem on LeroyC's mill last week. An added complication, the Dang breaker would not reset. Loosend the nut that holds the breaker in place and rapped the side smartly with a screwdriver handle. Re-tightened the nut and back to sawing..  GI maintenance  ;D
Peter Drouin
Quote from: Magicman on March 16, 2015, 09:26:44 PM
When I was on the road I had all that stuff too, And a big box of tools.
A&P saw Mill LLC.
Good quick fix. If a fellas mill is controlled by electrons its prudent to always carry a multimeter, wire, crimpons, and tape. Frank C.
terrifictimbersllc
Expecting no less from a master lineman.   Thinking I better put some wire in the truck.  Curious to hear how it was grounding out.
red
Just use taillight wires
21incher
Looks like you saved the day. Last time I fixed some wiring like that it became a temporary forever fix. :)
 :D  I was thinking the same thing.  My "corrugated" conduit has cracked and needs replacing, so I will figure out what happened at that time.
Which brings up the conduit subject.  What type flexible conduit is being used now.  How about a picture someone.  Yup, I could order it from WM but shipping?  If I could get it local, then it would save shipping.
4x4American
Magicman, how did you determine it was a ground?
Try a google search on wire loom.  It is good stuff, easy to work with, flexible, and readily available anywhere.  Get wire loom clips to easily mount it.
Boy, back in my day..
Quote from: 4x4American on March 17, 2015, 10:46:28 PM
The "other" side of battery is ground.  A multimeter is an essential tool.  :)
4x4American
So the multimeter told you that there was an open loop I would guess?  or wouldn't there be an open loop if it was a short or a ground because the breaker was tripped?
Come to think of it, it looks like the conduit they are using is wire loom!
Look at McMaster Carr  (mcmaster.com) and search "standard cable sleeving" for a wide variety of designs for passing wire through that are flexible. And I've found their shipping to be quite reasonable.
http://www.mcmaster.com/#standard-cable-sleeving/=wcukha
NWP
That looks like a permanent fix to me. At least if were mine.  ;D
1999 Blockbuster 2222, 1997 Duratech HD10, 2021 Kubota SVL97-2, 2011 Case SV250, 2000 Case 1845C, 2004 Case 621D, John Deere 540A, 2011 Freightliner with Prentice 120C, 2012 Chevrolet, 1997 GMC bucket truck, several trailers, and Stihl saws.
Ga Mtn Man
Magicman-
Check with Marty Parsons.  I recall that he said they had a bunch of this stuff.  Maybe his shipping charges would be less.
I would just like to see a picture of what WM is using now.  I am sure that it is available locally.
Sixacresand
It is pretty evident that MM knows every switch, where every wire goes and what it does.  Good Job, MajicMan.
Ga Mtn Man
The one on my 2012 mill looks exactly like yours.  So go take a picture of yours and post it here. ;D
Ga Mtn Man
OK Lynn, here ya go...my conscience was getting to me:
MartyParsons
Hello,
I will be flying to New Orleans tomorrow. I can throw it out the window on the way through. Air mail?
Marty
4x4American
