Arborwear
Author Topic: Homemade trailer mover  (Read 293 times)
Offline Kwill
  • Cedar cutter
« on: February 12, 2018, 05:29:44 PM »
I built this today to move my log arch and other trailers around. Just have to paint it. Works great.
Built my own log arch
In the process of building my sawmill
Offline ljohnsaw
Re: Homemade trailer mover
« Reply #1 on: February 12, 2018, 05:50:24 PM »
 8) That's a nice, stout one!  I have a cheap HF unit that I had to re-weld the handle back on.  Pretty high ball hitch on there!  I've seen them were there is a smallish caster on the front so when you bring it over-center, it rests on that.  That will keep it almost vertical and you can let go of the handle if you need to.
If I end up building a new one, I would put a receiver tube on it - then I could swap out different lift/drops to accommodate different trailers.
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline Kwill
  • Cedar cutter
« Reply #2 on: February 12, 2018, 07:42:12 PM »
Thanks. It works great
Licensing a homemade sawmill trailer. (specifically MI)
Started by Timberline on Sawmills and Milling
Last post February 12, 2015, 08:16:20 PM
by Tom the Sawyer
homemade axles for rough terrain log trailer
Started by Woodchuck53 on General Board
Last post April 24, 2008, 01:59:15 AM
by Woodchuck53
log mover
Started by Peter Drouin on Sawmills and Milling
Last post May 21, 2012, 11:08:05 PM
by Migal
My kindof new-ish log mover.
Started by Joe Hillmann on Sawmills and Milling
Last post August 07, 2014, 07:27:42 PM
by beenthere
