Arborwear
Author Topic: A public service announcement from someone not so smart.  (Read 1589 times)
Offline Crusarius
  • Lost in....
    • RockModified.com
« on: February 05, 2018, 01:04:55 PM »
So this weekend I was in the shop working on my snowmobile. I had a very stubborn bolt so I broke out the mapp gas torch. Well I kept trying to get it to light and it just wouldn't light. So I grabbed a firestick and tried to light that. Would not light. Got mad. went in house to get another one. Would not light. Started thinking....
Went outside map gas torch lit right up. So I went back in with it lit and heated up the bolt. After it shut off I tried relighting it. Nothing....
Well I think I realized after having the kerosene salamander running in the shop the carbon monoxide level was high enough that the torch and firesticks would not light.
PLEASE! BE CAREFUL. I didn't even think about the possible issues.
I had no idea my shop was that well sealed up. I have open eaves down one side of it. After opening up the front door the map gas lit and worked fine.
Now I think I know why I have been having a hard time catching my breath and been so tired after working in the shop.
I knew what I thought I meant.
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
Re: A public service announcement from someone not so smart.
« Reply #1 on: February 05, 2018, 01:15:28 PM »
Oh boy.  No headache?  I had two bad CO instances in my life.  One, in an ice shanty with one ofthose old dome catalytic Coleman heaters. Tremendous headache.   The other, much closer call when I was in my late teens putting high back bucket seats in my sport satellite in Tammy's grampa's barn, yes, with an old salamander running for heat.  They found me thinking I was dozing in the front seat Id just installed.  I was just real groggy. They Got me out in the cold fresh air and I came out of it, but was very sick the rest of the day, and in and out of a bad fog. Didn't know what happened that day, but came to realize what it was later on.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #2 on: February 05, 2018, 01:30:30 PM »
didn't notice a headache. or I did and just ignored it. Still scary to think about what could have happened. scares me thinking about my wife and son being in the house. how much of that got in the house. Plus what would they do without me? I can't even imagine my son growing up without a father.
Offline JJ
  • Gotta figure this out
« Reply #3 on: February 05, 2018, 02:40:04 PM »
That's pretty scary Crusarius, not enough air to light the torch.
I also had a close call with a old dome catalytic Coleman heater in a ice shack.  Picked it up from the dump, and used it just that one time.  Made me so sick, I left few tip-ups behind.  Went back next day to see if I could get them back, but somebody run over one with snowmobile and other was too froze, broke trying to get it out.
Took the heater back to the dump, hope nobody else picked it out.
         JJ
Offline Sixacresand
  • John and Nancy
« Reply #4 on: February 06, 2018, 01:18:58 PM »
Until about ten years ago, I used what I call a prefab fireplace, with the galvanized triple wall chimney, blowers, etc. Last Fall, when I had a metal roof installed, we pulled it all out.  I was shocked to see the chimney part had holes rusted through the pipes. This was a house fire waiting to happen.  As Sigh Robinson says " a piece of junk"
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #5 on: February 06, 2018, 01:39:49 PM »
it really is scary when you see stuff like that and you think how did I not lose everything.
You never seem to think about it till something happens to you or someone you know.
Hopefully this public service announcement helps someone.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #6 on: February 06, 2018, 02:27:35 PM »
I had an issue once with an LP construction heater.  Got really sleepy and realized what was happening.
Offline Ianab
« Reply #7 on: February 06, 2018, 04:44:07 PM »
Initially the effect is going to be the heater depleting the oxygen, and building up CO2 in the room. This will make you drowsy / sick. If you don't catch what's happening, the O2 gets so low the heater starts burning rich, and making CO. And that's when you end up dead.  A faulty heater can start making CO right away of course.
The effects of CO poisoning are more long lasting as it binds with your blood and stops it carrying oxygen around your body, so even if you get into fresh air you can still be in danger, and you usually need extra oxygen and hospital treatment.
You body can flush excess CO2 easily with a bit of fresh air.
Either way, lucky escape and a good warning.
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #8 on: February 06, 2018, 04:44:20 PM »
Possibly time to invest in some carbon monoxide detectors, I have them in an outbuilding that has a ventless LP fireplace and my house. If I'm just starting to lite my woodstove and the heater kicks on it has drawn some smoke back into the house, only one or twice but it has happened....finally the right place to post this.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #9 on: February 06, 2018, 04:48:27 PM »
Yea, I talked to the wife about getting some more. But I want ones that have an actual PPM readout on them. I never had the heater before so it was not much of a concern. I knew that when I was welding in the garage I was making alot of badness to inhale but never thought about a simple heater.
Offline moosehunter
  • Every once in a while
    • Saw it Coming
« Reply #10 on: February 06, 2018, 06:53:45 PM »
I hate salamanders. I get a headache if I just walk in to a room with one running. Glad you are ok.
mh
If it is true that we learn from our mistakes, I must be Brilliant!
Offline Don P
    • Calculator Index
« Reply #11 on: February 06, 2018, 07:27:28 PM »
One gentleman I worked for liked to make wine, in quantity. There was an old basement icehouse in the back yard that he did it in. Ladder down into the smallish underground room. CO2 is heavier than air and the wine was making plenty of it. Luckily he realized what was going on, started climbing and passed out in the yard. I hate to think what would have happened if he had collapsed back into the pit.
A couple of years ago we were digging out a basement under a house and had the bobcat under there. Even though we had knocked a hole in the wall and made a ramp to drive down in there, same thing the fumes began to settle in there with us. Luckily one of the guys realized we were getting stupid, well and being stupid. It is so easy to do.
Online POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #12 on: February 06, 2018, 07:55:25 PM »
This was a good Post. Makes us think. Thanks.
Where's the Spoon?
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #13 on: February 06, 2018, 08:07:09 PM »
I was at an auction years ago and they has a new salamander heater.
It was up for sale but they was also using it at the time to heat the auction
building. Something happen to it and it started to really stink up the place.
I got that new salamander for $7.00 and it's still working great today.
It sure cleared out the building of almost all the buyers.
Love machine shop work
and Wood work shop work
And now a saw mill work
« Reply #14 on: February 06, 2018, 08:29:08 PM »
There was no doubt in my mind you bought it.  :D :D :D
Where's the Spoon?
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #15 on: February 07, 2018, 07:41:24 AM »
Wondering if those "Mr Heaters" are a danger!   ::)
We have used them in hunting shacks!
Don't recall anyone ever having headaches or grogginess!
~Chuck~
I LOVE MY SAWMILL
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #16 on: February 07, 2018, 07:50:24 AM »
Chuck in concentrations that small and for short periods of time I am sure you were exposed but nothing that would get you to any life threatening level. The headaches don't start till stage 3 I think. My FD training on CO was quite a while ago. I don't remember all of it.
Offline Don P
    • Calculator Index
« Reply #17 on: February 07, 2018, 08:20:52 AM »
Somebody that passed chemistry might want to correct this. My understanding is that a yellow flame is producing monoxide, CO. Carbon has 4 bonding sites and oxygen fills 2, so CO needs to find another O to be stable. It will pull that other O out of you. A hyperbaric chamber is the best first aid if there is one available.
A blue flame is producing CO2, which does us no good respiration wise but is not "harmful", and it is consuming the O out of the room, so crack a window. I think that is what happened in Crusarius' shop, the salamander had eaten up the oxygen. That ain't good either!
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #18 on: February 07, 2018, 08:23:53 AM »
Definitely ate the O in the shop but the other part is it displaces the O in your blood. that is why long term effects you more than short term.
Offline JimTwoSticks
  • Killed a grouse with two sticks once
« Reply #19 on: February 08, 2018, 12:32:10 PM »
They sure are Chuck!
A Mr. Heater produced sweet revenge on a couple friends of mine in high school (only because they weren't seriously hurt)  :snowball: . They had a nice insulated (but small) two man ice shack with a Mr. Heater. Temp had to have been well below zero but I can't remember. I froze half to death without a heater in a clam. They spent the next day or so trying to piece things together through their blinding headaches. Nothing like CO poisoning on top of heavy alcohol consumption, er I mean water consumption, we were in high school :)
Enlisted into public service...
Started by Rooster on LogRite Tools and Rite Leg Co
Last post March 28, 2014, 11:54:13 PM
by Rooster
Public service anouncement. Eco-terror.
Started by Tillaway on General Board
Last post November 04, 2002, 01:51:40 PM
by swampwhiteoak
Full service Service Stations. I miss them.
Started by POSTON WIDEHEAD on General Board
Last post September 30, 2014, 09:24:06 AM
by dablack
For those who KD for the public
Started by brdmkr on Drying and Processing
Last post April 13, 2007, 10:43:19 AM
by BC Woodworks
