General Forestry => Sawmills and Milling => Topic started by: kelLOGg on October 02, 2011, 07:08:36 PM
This has probably been done before but I don't recall having seen it.
(https://forestryforum.com/gallery/albums/userpics/13036/832/bowing_cant_001.jpg)
Saw to the clamp, install a 2nd one w/ a spacer under it to prevent binding the blade, remove the 1st one. Saw more and repeat if necessary. Example shown is with sweet gum. I suppose for larger cants you could use a pip clamp on each side.
Bob
(https://forestryforum.com/gallery/albums/userpics/22539/2903/1009001750.jpg) I have bolted a mount on end of bowed cant so i could get a ratchet strap to help bring it down, and also put some weight on top with another cant.
Redbeard, I like that. For a cant w/ ends bowed up your method doesn't require removing anything.
smiley_idea I thank both of you for the ideas. :)
With a center hump bowed, I only need to hold it down until I get it clamped. smiley_thumbsup
And for a small bow -- say 1/4" in 16', I put the hump up, clamp it ever so gently, then give it a whack or three with a dead-blow hammer. Once it's good and flat I tighten the clamp right up so sawing vibration doesn't release the timber.
Both ideas are good, thanks Steve
