General Forestry => Firewood and Wood Heating => Topic started by: old joe on December 04, 2008, 11:49:46 AM
Has anybody built their own design owb? I'm not a great welder, but I think I can , with some good design advice. Any response will be greatly appreciated. I have an almost unlimited supply of dead and down wood, and 5000sq' in three buildings to heat . thanks joe
old joe
This design you are after to heat water, and then pump it to the buildings?
I've a small wood 'boiler' inside to heat water, and it is a very simple design. Essentially a barrel within a barrel. I cannot replace it, so if it gives up I will approach a local welder to get the 1/4" steel rolled, then have it welded with no leaks, and use the same cast door that is on it now. It is simple and very effective. Has a 9 gallon water jacket around it.
(https://forestryforum.com/gallery/albums/userpics/10180/WoodboilerbaFF.jpg)
Thanks, I've got a 500gal propane tank for storage and want to make a heat exchanger at the firebox I'm going to try to convection feed the tank . What do you all think??
I have been thinking about doing one as well. Use brick in the firebox on bottom and three sides for hotter firebox temps. Then pass the flue gasses thru a set of firetubes and out the chimney. The one I use now is completely surrounded by water and never gets hot enough to burn completely. Joe
I made the firebox out of a 30 gal. water pressure tank . 6 in. stove pipe out the top, 12 in door. its about 18 in diameter
Next I'll build 2 6 tube collectors out of 2" galanized pipe and bury it all in a sand filled cement block box.
