What is this?
Started by Bark Beetle, January 29, 2017, 05:27:13 PM
Bark Beetle
We found the smaller piece first a few years ago and just today I found the larger one not very far from where the first was found
You don't work wood, you work with wood.
samandothers
A guess would be part of an old axle, but I don't know for sure.  Look forward to others indicating with some certainty!
Dave Shepard
Is the smaller piece made of lead?
Autocar
Part of a old hand water pump maybe .
Bill
Kbeitz
The the tapered part of a wagon axle.
called a cast skein.
Love machine shop work
and Wood work shop work
And now a saw mill work
luvmexfood
Looks a lot like an old valve used on a water trough. Modern ones are made of brass and a piece that comes out the top that you attach a rod to with a float on the end. When the tank fills up the float on the rod pushes the piece on the valve down shutting off the water flow.
Give me a new saw chain and I can find you a rock in a heartbeat.
elk42
Machinist Retired, Lt15 WM 25 HP, Stihl 044, Stihl 311, Kubota M2900w/FEL, KUBOTA L4800 w/FEL,
Lincoln Ranger 10,000, stihl 034,
It's part of a model a driveshaft. I'll try to find the pic of the one I used to make a grinder base this summer.
ozarkgem
I'm going with the wagon axle. No bolt hole flanges. I kind of remember seeing them laying around as a kid.
dustyhat
Sorry, but everybodys wrong. its a wagon ( Thimble )  ;D o elk had it right.
yukon cornelius
Wagon thimble it is. We found a near identical one online. I never would have expected that. We thought when we found the first piece it was part of a pump. We found it in an old creek crossing. I was amazed when we found the second piece today. They definitely go together.
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
Bark Beetle
Is the socket on the side for self oiling/greasing? It has a hole that goes from the socket to the axle of the thimble.
Kbeitz
Ox
From what I see with a quick search,  wagon skein and wagon thimble are the exact same thing, just different terminology.    Both are right, right? (Tom)
Bark Beetle
Don_Papenburg
Yep that's it, the tapered part is s'posedto be covered in grease
