help with wiring control cable to terminal strip nyle l53
Started by John C., August 11, 2012, 09:15:54 AM
John C.
hi,cant figure out last two wires on the treminal strip.one says  neutral and the other says ground.the last two holes on the strip are both  labeled N.the others were all numbered.nyle is not open today.
thanks john
John C
Not privy to seeing just what you are dealing with for certain, but on a three prong plug for 110v AC drop, there is a ground, neutral, and hot wire.
The neutral (white) and hot (black) are there to complete the circuit, the ground (green) is there keep you out of the circuit.
Don't know if this helps.
