Pictures of mill (Belsaw M-14)
Started by Little Jim, January 09, 2014, 07:32:34 PM
Little Jim
  This is my first attempt at posting pictures of my little mill. I thought some of you Belsaw fellows might like to see them. I sure have enjoyed looking at all of yours and getting lots of idea during the process. If this works I will post some others.
jerry-m
  Very nice set up... Pictures are great, thanks...
  One thing you might consider is adding a piece of plex a glass to your chip screen...
  Jerry
Jerry
You did a good job rebuilding and setting up your mill Jim. Your wise to have built the turning blocks they will save your carriage. Do you usally cut alone or have help.?? Frank C.
Wellmud
That baby looks new again, very nice.
Woodmizer LT35 manual, Kubota L3130, Farmi 351, Stihl 029 super, 3 Logrite canthooks
Possum Creek
That is one nice looking belsaw. I am very impressed, it is nearly to clean to use.   Great job.                  PC
61Scout80
Jim,
What a great looking M-14 mill and shed!  What are you using to power the mill?
"Don't measure yourself by what you have accomplished, but by what you should have accomplished with your ability."
John Wooden
stoverguy
Dang that is nice! I expect you will find the sawdust the next thing to tackle. I get an incredable ammout of sawdust without a pit and chain to take it away. Sawing hard, you will have to stop every 1/2 hour or so just to clear it out. It really adds up fast. I see you only have two knees. They are pretty light. I have the three knee setup and even that kept comming loose on me. The light strap that ties the knees down to the C channel kept slipping and bending letting the uprights get loose. With only two you are going to know what I mean pretty quick. I tried to "beef them up" with a plate welded in but it only made it better not good. I replaced mine with an L shape plate that has a lock bolt on top and and roller underneath. I should take a picture. Pretty simple, I made mine myself, but you will need access to a milling machine to cut the height adjustment slots.
c greenham
Very nice looking mill.  I am a big fan of these types of mills it speaks volumes of our forefathers which built this industry.
dustyjay
Awesome! That is inspiring. Cold weather and full time work has slowed my mill build. That looks so slick with the paint job. I plan to do doors a lot like what you have for your skidway. Nice and buttoned up.
Proper prior planning prevents pith poor performance
Little Jim
What is your control or shut-down procedure for the PTO power to the saw?
Overhead?
Babylon519
Hey Jim, nice to see another one prettied up! That's a good solid staging area you built - would you make any changes to that if you were building it again? I'll make one this spring, and I could learn from you... (I have been using a trailer for staging, but want something more permanent).
Nice project, well done! -
  Jason
Jason
1960 IH B-275 - same vintage as me!
1960 Circle Sawmill 42"
Stihl MS440 & a half-dozen other saws...
MIsawyer
That is a great setup you have there
The rebuilding is done. Good luck sawing.
hardtailjohn
Nice!!
Stoverguy...I'd like to see pictures of what you're talking about. I have a 3 knee, but need a dog for the 3rd.
John
I'm so far behind, I think I'm ahead!
drobertson
Joe Lallande
Take a few pictures of your power.
dgdrls
Welcome Little Jim,
That's a dandy set-up,  love those circle mills smiley_thumbsup
power??
DGDrls
sdunston
WM LT28, American fordge 18x8 planer,Orange and white chainsaws, NH TC33, IHT6 dozer, IH-H tractor and alot of other stuff that keeps me agravated trying to keep running
hardtailjohn
Quote from: bandmiller2 on January 09, 2014, 09:12:01 PM
One question I have.... would it work even better if the turning blocks were even a bit further back? That way the cant would transfer all the shock load to the deck instead of the carriage, and you just shove it back on, already fully turned?  I realize it would be a bit more work shoving it back on that way, but am I just going too far?
John
thurlow
Quote from: hardtailjohn on January 12, 2014, 01:02:30 PM
John
Certainly not knocking anyone else's set-up.......and the mill looks great, but......I've never thought I needed turning blocks.  I just flip the cant onto the deck and then slide it back onto the carriage.
Here's to us and those like us; DanG few of us left!
John, when you turn the cant you use your cant hook which tends to slide the cant to the bottom of the turners as it flips over on them with very little impact on the carriage. Thurlow your system works but the triangular turners let the cant slide back on the carriage easily. I don't have a Belsaw but use that type of turner on my Chase mill. My turners are hinged and have truck air brake cam rollers to help scoot the cant back on the carriage. It helps if you have wood turners to put a strip of steel or Teflon on the incline to make them slicker.
Possum Creek
I made some turners out of 6" channel iron cut 45 deg. with a plate welded on the cut side for the log to slide on. They are on hinges like bandmiller2's are. I ain't saying its the best way but it sure saves me lots of pushing.        PC
iwiegian
Very well done little Jim. I just purchased an M-14 and I sure hope it ends up even half as nice as yours.  Like you I plan on using turning blocks. Dave
