Rope Anchor to Vehichle for Tree Pulling
Started by ECSScott, September 14, 2018, 11:38:13 AM
ECSScott
I have always used a regular clevis in a hitch to tie off tree rope for pulling.  The radius is really small on a clevis so i was trying to come up with different solution that would have larger diameter of at least 4".  Was not sure if i hook a pulley to the hitch and then tie rope around that or not.  Does anyone have any suggestions for hooking rope to vehicle?
John Mc
The knot itself is probably weakening the rope more than the clevis hook. Even if you went to something with a 4" diameter, you still have the bends in the knot.
DelawhereJoe
HolmenTree would be a great person to ask as he runs a one man tree service and has posted several pics of him using his truck to  pull trees that are leaning or fallen against houses.
mike_belben
Baileys sells little plastic eyelets .. I think they might be called thimbles??  Anyway theyre not too large but they double the radius of the initial bend which puts more of the fibers in tension, adding some strength. If half the rope is in compression then youre working with less diameter.
A hitch ball will add some radius, just be sure to go around the hitch tube also so that your loop cant pop off.
Praise The Lord
lxskllr
Maybe a piece of pipe welded to a receiver tongue.
ECSScott
Has anyone used something like the Bend Right Rigging Ring?
lxskllr I thought about taking a pipe and chaining it through the ends to the hitch.  Then wrap rope around pipe and tie.
HolmenTree
Scott,
Only one way to tie a rope to a pickup truck.
I use a Bee-Line eye to eye prusik, doubled like in my pics 16K breaking strength or approx.11K tensile doubled.
I put it on a strong stainless steel carbiner.
I never had a problem with this setup and have pulled some big loads with my 6.7 Cummins diesel 4x4 pickup in low range.
Always attach to front hooks and pull backwards .
HolmenTree
Here's the tensile rating in single eye to eye.
ECSScott
Do you pull it like in your picture without a knot in the pulling rope?
HolmenTree
Quote from: ECSScott on September 19, 2018, 12:19:24 PM
Scott, on this 3/4" stable braid rope yes. The prusik will move about a inch then it will cinch.
This method is super easy  to tie  and untie. Plus highly adjustable.
On smaller diameter  rope I go one extra wrap from 2 to 3 to prevent slippage.
DR_Buck
A more basic question would be "If you're concerned about the rope breaking because of the clevis radius, do you really think you should be tying it to a vehicle?"
It's all about physics.  If your vehicle is a multi-thousands of pounds piece of logging equipment then you are probably OK.
Skeans1
Best thing I ever learned don't line a tree with a rope or a light machine it's always fun watching a rig get pulled backwards or a skidder. Myself if something really needed lined I'd want at least a D7 on that line it might be overkill but if it breaks that cable or drags that 50k+ machine then it's probably something I shouldn't be messing with.
firefighter ontheside
As long as the diameter of your clevis is larger than that of your rope, the knot is the weakest part of the whole system.  It will break there before it breaks at the clevis.  Any bend in the rope weakens the rope.  What knot are you using?
Figure 8 has the best efficiency.  In rope rescue we switched from bowline to figure 8 years ago because of that.
Woodmizer LT15
Kubota Grand L4200
Stihl 025, MS261 and MS362
2017 F350 Diesel 4WD
Kawasaki Mule 4010
1998 Dodge 3500 Flatbed
John Mc
Quote from: firefighter ontheside on September 20, 2018, 10:18:09 AM
A Butterfly knot generally has better strength than a figure 8 knot, but a figure 8 is stone simple to tie and to inspect.
As you get into smaller diameters, a Double Fisherman's knot will even beat a Butterfly knot - but it has some real disadvantages - one being that once loaded it is extremely difficult to untie.
HolmenTree
My experience tying a rope directly  to a pulling vehicle towing ring etc is the Anchor Bend knot or hitch.
Very strong with its 2 non crossing leg coils  and easy to untie.
Rather then just pushing a straight end of the rope under the 2 coils for termination, I make a slip  with long doubled bight with the end of the rope.
Then when I go to untie I pull the excess end of the slip in the bight.
Al_Smith
If in the very rare event I have to power pull a tree I don't play around.I have 2 600 foot reels of 1" three strand nylon and 1 300 foot reel .I just use a bowline and a big shackle  and often with a snatch block two part line .I've also got 100 foot hanks of double braid Plymouth 5/8" but I don't use them to pull .
I might add I learned my rigging education from working as an industrial electrician that spanned 47 years .In that time period I've rigged pulls of armored cable of up to 2000 feet in length with cable that weighed 12 pounds per foot .I have never had a rope,splice of any kind or a shackle ever fail .
HolmenTree
I only covered the pulling anchor point , but tying to a standing tree a running bowline works every time.
A standing tree pull calls for a big shot slingshot on a 8 foot pole shooting a throwline and weight bag to get the rope up (best invention ever)
Here  I cut and pulled a 65 ft poplar that had a heavy side and back lean behind a shed and over 12K volt wires.
With 2 block pulleys, slings and lots of 3/4" stable braid rope attached to my pickup got er done. :D
HolmenTree
I had 2 ropes rigged into that tree. One to pull on 2 anchored block pulleys with the truck. Plus another anchored with a 6 ton come along acting as a 90° degree to lay side rope to guide the tree down along side the shed and garage.
teakwood
And how did you do the cutting and pulling by yourself?  I know you work alone and that would be impossible.
Man, that was a difficult tree, congrats on the success! You aimed it perfectly, a little to the right and that shack would have been damaged. How do you do the cut on that height, with a ladder?
HolmenTree
Quote from: teakwood on September 23, 2018, 09:14:20 AM
Yup been working alone for 10 years now.
No ladder.... after I got the 2 ropes all tensioned like a fiddle string I felled it making the cuts 6 feet high above my head.
Couldn't do it without these tools here. :)
lxskllr
HolmenTree
Quote from: lxskllr on September 23, 2018, 11:44:28 AM
What do you do with the ruler/square?
I use the T square for sighting in anchor points for  90° degree to lay guy ropes on heavily side leaning trees.
Plus for gun sighting the facecut to lay in tight quarters.
When you're in the business 5 days a week removing trees in residential and commerical properties  you need precision gun sighting. The sight marks  on the saw are not good enough
If I can't find a 90° degree to lay anchor point for guying, I make one like this.
teakwood
Interesting Willard
So you never have to cut and pull at the same time?
HolmenTree
Quote from: teakwood on September 24, 2018, 08:34:07 AM
Interesting Willard
Like I said earlier if I have enough tension in the pull rope whether it's on the truck or ratchet puller on a back leaner I can just cut and the tree falls.
But if the back lean is too heavy I bore cut the back cut, leave a strap so the tree is not committed to fall.... for safety.
Then right before I go to the truck to pull it over I make a cut into the tree  deeper then the thickness of the backcut strap... about 6 to 10 inches below the strap.
When the truck pulls... the strap wood breaks free.
lxskllr
I'd love to work with you for a couple weeks to learn some of your technique. If I were a kid, I'd offer to do it gratis, just for the learning experience. As it is, I'm too far away, too old, and too tied to my existing job to make the offer  :^/
