KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
BRUTE FORCE Authorized Dealer
Council Tool
Author Topic: Picking up my fist mill  (Read 1828 times)
Offline Treehack
  • So many logs...So little time
Re: Picking up my fist mill
« Reply #20 on: February 13, 2018, 09:59:12 AM »
Welcome to FF.  Glad to see you starting small to get your feet wet, you can always upgrade later :D :D :D
TK 1220, 100+ acres of timber, strong left arm.
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #21 on: February 13, 2018, 10:52:48 AM »
Sounds like a nice unit! At 100 hours itís just getting broke in, if might even have the first scratch already, saving you that first scratch tear lol
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummings,
Offline crosswind
« Reply #22 on: February 13, 2018, 12:17:34 PM »
I didn't want to pull it all the way to Mi through the salt and wet conditions so my nephew and I are picking it up on his 53 ft flat bed with a curtain to keep it out of the elements.
Should be loading it around 5 pm today.
Offline GAB
« Reply #23 on: February 13, 2018, 01:38:31 PM »
Try to not saw in the presence of visitors, especially other sawyers for a while. That;s usually when backstops and clamps get in the way of the blade.. ;D
Another thing likely to happen with spectators around is changing blade and having the teeth pointed in the wrong direction.
It just does not saw.
Gerald
W-M LT40HDD34 w/6' ext & SLR, JD 420, JD 950w/loader and Woods backhoe, V3507 Fransguard winch, Cordwood Saw, 18' flat bed trailer, and other toys.
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #24 on: February 13, 2018, 04:07:56 PM »
This is spot on advice.  I have been sawing for right at 10 years and most of the time when someone comes up, I shut her down.  Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline slider
  • sawyer,trucker,tree service
« Reply #25 on: February 13, 2018, 04:34:45 PM »
My first mill was set up by the road . My friend i bought it from suggested i should move it back in on my place to learn without on lookers . When i got home the next weekend my neighbors had chairs set up. So much for trying to hide. That was 18 years ago. Good luck and welcome.
al glenn
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #26 on: February 13, 2018, 08:51:31 PM »
   I wish I could get more mobile jobs by the road. Great advertising. I tend to be at the last house on a dead end road or out of sight in a pasture or woodlot. That is better for overnight security, when required, but less so for advertising. The customer still normally calls over a couple of buddies who sometimes come help, sometimes just watch. I do like making the extra contacts. No telling when it will pay dividends in the future. My son suggested I get some of these wire-legged signs and put one by the road and one by the mill when I am sawing. I may think some more about that.
   The extra eyes are nice but they can cause a dip in production and you have to be careful that nobody gets in an unsafe area. If I do make signs maybe I need to put a caution on there for that and have a little box/tray for business cards.
Help needed picking a mill
Started by timjab on Sawmills and Milling
Last post May 02, 2010, 08:39:47 PM
by jfl
Picking Up New Mill On Friday
Started by wwsjr on Sawmills and Milling
Last post May 13, 2013, 08:17:00 PM
by francismilker
Picking up the new mill today
Started by windy hill farm on Sawmills and Milling
Last post July 10, 2011, 08:14:31 PM
by windy hill farm
Need advice in picking reasonable saw mill.
Started by alsayyed on Sawmills and Milling
Last post January 28, 2008, 11:42:02 PM
by ErikC
