Council Tool
Author Topic: Today's junkyard find.  (Read 64397 times)
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Today's junkyard find.
« Reply #660 on: February 12, 2018, 08:15:50 PM »
Quote
I have one of these!  Came out of a motorhome, and is 4,000 watt and runs at 1,800 RPM!
Only issue I have is I need a coil for it!  It takes what is referred to as a double coil!
Seemed to run forever on 5 gallons of gas!
The coils are on E-bay often.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline pineywoods
« Reply #661 on: February 12, 2018, 08:44:12 PM »
The 4kw onanas were used on motor homes that had only 1 rooftop air conditioner. The coils are unique, but can be had. They fire both plugs at the same time..A clutch off of a golf cart will fit the tapered crankshaft with a little lapping.
Offline Al_Smith
« Reply #662 on: February 12, 2018, 08:56:34 PM »
Same coil as a Harley Davidson ,cheaper .
Offline Al_Smith
« Reply #663 on: February 12, 2018, 09:14:40 PM »
My parents had a 7500 Onan with a 3 cylinder Yanmar water cooled diesel on a motor home ..It would not carry the load until it reached operating temperature nor shut down until it cooled  below a certain temp .Very well designed .Glow plugs, it probably would have started on the North pole .
Being a 4 pole generator running at 1800 it's probably a 16 or 18 HP engine .Should be able to tell from the engine name plate by referencing the model number .
We had a little Miller welder generator with a pancake Onan .3600 RPM  for welding which was about 5 quarts of gas per hour .1800 for generation which I have no idea but it went a long time .It was an 18 HP if memory serves .,5,000 watt .
Offline Percy
  • Resident trouble maker
« Reply #664 on: February 12, 2018, 10:34:10 PM »
An 873 is a serious machine. For 1500.00, that is like stealing. Some would pay more than that for an 873 carcass ;D
[/quote]
But I'm kinda disappointed that it's not a kubota engine.
It has a Deutz in it. Are they any good?
[/quote]
One of our A300 Bobcats has a Deutz in it. Great engine. No antifreeze. Just oil and air for cooling. Always starts. Stingy on fuel too.
Offline Kbeitz
    • My Hobbies
« Reply #665 on: February 13, 2018, 06:53:29 AM »
No antifreeze ? Wow. New one on me ... Thanks.
Offline paul case
  • Original wearer of the PCM.
« Reply #666 on: February 13, 2018, 09:21:44 AM »
Yeah those Duetz engines are air cooled. They have a screen on them that needs to be kept clean, at least the tractor engines do.
PC
pc
Offline Kwill
  • Cedar cutter
« Reply #667 on: February 13, 2018, 01:48:09 PM »
My neighbors have a duetz  tractor. Its really good on fuel and has been a really good tractor. Always starts even when the big JD won't .
Built my own log arch
built my own bandsaw sawmill
Built my own atv log arch.
Built my own FEL grapple
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #668 on: February 13, 2018, 04:03:22 PM »
Kbeitz there should be some kind of alarm to let you know if the belt breaks or comes off.  That or some kind of tattle tale switch to shut it off should that happen.  Without the fan turning the motor will be toast pretty quick.  Use to have a couple Liebherr 921 trackhoes.  They had the air cooled Deutz,  My ex partners little brother got one of them too hot....not good.  Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline Kbeitz
    • My Hobbies
« Reply #669 on: February 13, 2018, 05:42:52 PM »
Looks like I'll have a lot of new to learn...
Offline Don P
    • Calculator Index
« Reply #670 on: February 13, 2018, 06:21:33 PM »
Nice engines, we swapped one out a month or so ago, figure the original one was over 40 years of hard service old;
Opinions on Deutz engines??? in Forestry and Logging - Page 2 of 3
Good idea Banjo, maybe something like a tensioner type wheel riding the belt, when it drops in a switch to a dash light closes.
Offline pinefeller
  • youngest sons first sentence: "Pa cuts trees"
« Reply #671 on: February 13, 2018, 08:08:40 PM »
oil cooled  ;) mine has 10k hrs and burns no oil and the oil is still clean at 200hrs after an oil change.
for those who say "it cannot be done!" please do so quietly so as not to disturb those who are doing it.
Offline Kbeitz
    • My Hobbies
« Reply #672 on: February 13, 2018, 08:23:37 PM »
Share what kind of oil you use....
Offline pinefeller
« Reply #673 on: February 13, 2018, 09:04:00 PM »
i was actually giong to call the guy that did it last and see what he used, its due again. i was told this phenomenon has to do with being oil cooled instead of antifreeze and not being turbo charged. im pretty shure he said texas refinery so it should be rotella t (i believe shell is owned by T R. im used to losing a half gallon or so between changes in pretty much all large equipment ive maintained and black oil by 200hrs. this engine has been unbelieveable, no leaks, no burning, good power and pretty quiet.
Offline Kbeitz
    • My Hobbies
« Reply #674 on: February 14, 2018, 03:27:52 AM »
That would be great. Rotella is what I use in everything I have except
my cycle.
Offline Kbeitz
    • My Hobbies
« Reply #675 on: February 14, 2018, 12:38:26 PM »
All mine ... Done paid for. I just gotta get it home.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #676 on: February 14, 2018, 02:00:41 PM »
Awesome deal.
the tires are funny. those are airless tires worn all the way through to the suspension circles. They should be at least 3" taller
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #677 on: February 14, 2018, 03:45:03 PM »
Hiring a rollback can be the simplest, and relatively cheap.
We move our JD 250 with a car trailer occasionally, but it's a bit overloaded.  If you do that, block the midpoint of your ramps or they may not slide back into their "home".  Just like ours no longer do thanks to my brother.   ;)
Lucas 6-13+slabber, Mr. Sawmill bandmill, orange chainsaws, JD SSL, Case Backhoe, farm tractors, trailers, and 150ish acres of trees.  Fledgling woodshop with CNC router, laser engraver, Woodmaster 712, and a Berlin 108 moulder (project).  Oh, and a lovely (patient) wife and four offbearers.
Offline Kbeitz
    • My Hobbies
« Reply #678 on: February 14, 2018, 05:53:35 PM »
I'm lucky. My son owns a large rollback. The junkyard is just so muddy and icy
that I'm just going to wait till things dry off a little.
« Reply #679 on: February 14, 2018, 07:00:50 PM »
My money would be on Kbeitz finding a new set of tires for it there in a little bit.  Banjo
Draw Knife Find and Junkyard shave Horse
Started by Jason_AliceMae Farms on General Woodworking
Last post March 30, 2014, 10:45:19 PM
by hackberry jake
Strange find today!!!!
Started by Woodhauler on General Board
Last post August 20, 2014, 06:13:40 AM
by timberlinetree
Going to find a doctor today!
Started by Woodhauler on Health and Safety
Last post February 25, 2015, 05:33:11 AM
by Woodhauler
A nice find today
Started by Magicman on Sawmills and Milling
Last post September 04, 2011, 09:37:33 PM
by beenthere
