log chairs
Started by yukon cornelius, July 02, 2014, 10:30:24 PM
yukon cornelius
here is something else I made for a guy last week. I just modified my porch bench plans that I make. made them taller and narrower and a bit deeper. exactly the same, only different haha!  they were made with GREEN cedar logs. the kind tht drip on you as you peel them. the customer was really happy. I liked them too. I will add these to my "list O stuff" I make. let me know what you think.
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
I like em! How did you secure the tenons?
yukon cornelius
I drill the mortise half through the leg then drill through the center of the mortise with an 1/8" bit and 3" screw and glue them (gorilla glue). the screw is counter sunk and 3/8 dowel rod pegs the holes to hide them.
POSTON WIDEHEAD
Excellent Yukon. Really, really nice.  smiley_thumbsup
21incher
They look great and should last forever. Good job!
LeeB
I have considered doing the same, only using sticks for the seat slats. Might not be strong enough though.
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
ozarkgem
Hey Larry where are you finding Cedar that white?  Looks pretty good.
yukon cornelius
if we peel cedar that green its that white. these were peeled same day as they were cut. we use a paint scraper in these green ones and the bark can easily be peeled almost in one piece. also there is nearly no sanding necessary.
ozarkgem
Quote from: yukon cornelius on July 06, 2014, 12:10:42 AM
are you putting any finish on them?
yukon cornelius
no finish on these. I don't know if any finish would work on anything this wet. a long time ago I tried oiling some greener logs and they turned yellow. once peeled cedar dries really fast.
samandothers
very cool! Would look great on my front porch!
Busy Beaver Lumber
very nice. Love those chairs
Woodmizer LT-10 10hp
6 x 10 dump trailer
Grizzly 6in Spiral Cut Joiner
Twister Firewood Bundler
Jet 10-20 Drum Sander
Jet Bandsaw
Save a tree...eat a beaver!
