TJ330 Center Pins
Started by deerguy, June 03, 2014, 05:42:57 PM
deerguy
As my TJ330 gets closer to my goal of completely re-built, there is one job left to tackle. I plan on splitting ol' Beatrice this winter to re-build the center pins and I have a few questions.
Are there kits available either factory or aftermarket that supply the eyes and the pins ?? Is it easier/cheaper to do it myself with the help of a local machine shop ??? Are there other issues besides the center that I should address while Beatrice is split ??
Any comments, suggestions and /or pointers very much appreciated !!!
Since I'm nearing the end of this amazing process, I want to do it right and hopefully only do it once !!!
Thanks, Deerguy
I knew she was a keeper when she told me to buy the old skidder !!!!!
treeslayer2003
Quote from: deerguy on June 03, 2014, 05:42:57 PM
Thanks, Deerguy
machine shop is cheaper in my expieriance. you will need new pins, weldments for the egged out holes, thick bronze washers and steel shims, and shperical bushings........check e bay for them. should be 1-3/4" id....IDK a 330.
now is the time to check or replace drive line bearings and u joints in the center.
jwilly3879
We just had Swinton's Logging Equipment Repair replace ours in the 240 and Andy was done in about 3 hours. I don't know how he does it so quickly.
Neilo
The self aligning bush is the same on the 330 and the 200 series. p/n 102820
The hinge pins are different. 330 p/n 501059 plus washer 500878, spacer 501058 and thrust washer 200327
Neilo
