cutting weeds/grass on dam
Started by ljmathias, November 25, 2017, 09:28:00 PM
pineywoods
There's a reason the pro's use a hydraulic motor powered mower on the end of a boom to do this kind of mowing. An old push mower sounds like a good idea, BUT after a hour or so, the old briggs goes bang bang and seizes up. Most small gas motors, when tilted more than about 15 degrees, the splash lubrication for the con rod ceases to do the job. Unless you can find one of them REAL old lawn boy's with the 2 stroke motor.
Al_Smith
On that splash lube the 18 HP twins can be tipped to the left but to the right it will hang in a very short time .Snaps the connecting rods like tooth picks .I knew that but the former owners of two blown twins at my shop did not .
Al_Smith
An observation on zero turn mowers .It seems to me by design those that have the caster wheels in front will hold a slope much better than those with trailing casters .My Toro does good .My father had a Grasshopper that didn't .He'd get that thing stuck in a ditch bank and had to get his Jeep to pull it out .
Having said that just this past summer my buddy put about 3 feet of his Toro in his pond .He had a 4 wheeler on hand to save the day .
Another thing why pray tell they ever put tubeless tires on a lawn mower I'll never know .I tubed mine and as of yet never had a problem rolling the bead loose on a slope .Prior to I had a lot of problems .
John Mc
Quote from: Al_Smith on December 03, 2017, 06:14:10 PM
Al - Are you referring to a specific brand of engine? How do you tell which way is left and which is right on a vertical shaft engine? (On a horizontal shaft, I'm guessing left and right are as view from the output side of the engine?) I'd love to get it straight so I can favor the best side when operating on a slope.
Al_Smith
Briggs vertical shaft flat head,14 to 19.5 HP .The grass blows out the right side referenced by being in the seat .You have to blow the grass up hill on a slope .
If I'm not mistaken the Kawasaki and Kohler engines are pressure lubed while the Briggs is a splash .
On that though the only thing I've personally seen the flat head used on was tractor type mowers not zero turns .
Al_Smith
Now talk about small engines my dad had an old Ford rider with a 16 HP Kohler single .That thing had a piston about the same size as a 350 Chevy .It high grass all it did was get louder .I think it's still sitting in the barn,has to be 40 years old .
YellowHammer
Quote from: Al_Smith on December 03, 2017, 06:23:31 PM
We bought our Kubota Zero Turn for the purpose of mowing slopes that were way too steep for our tractor.  They are very low center of gravity and extremely stable when side sloping.  However, when they slip, the best maneuver is to spin the castors downhill, and simply roll and mow downhill.  However, when both back tires are slipping when going down hill, its too steep.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Kbeitz
Yep... Been there ... Done that...
Love machine shop work
and Wood work shop work
And now a saw mill work
Kbeitz
I got plenty of time mowing steep banks.
LittleJohn
Saw one of their ads the other day for these guys, Brielmeyer https://www.brielmaier.com/en/brielmaier-in-action/am-berg, not sure of cost or if they are even in the States.  But they sure do look pretty INTERESTING
DelawhereJoe
Interesting....I'd say, looks like the sicklebar mower to have for the zombie apocalypse. It would give a literal meaning to mowing them down.
Crusarius
I put atv flotation tires on my zero turn because of the many times I slid into the pond. Best $60 I ever spent on it. Only thing is you cannot do a 180 degree turn unless you are rolling. It will tear a small circle in the grass.
samandothers
Quote from: LittleJohn on December 04, 2017, 03:32:29 PM
Well that is quite a bit more fancy than my 2 wheeled Gravely with sickle bar!  I might have to add dual wheel adapters.
Al_Smith
They make "hill side" mowers .I've seen both tracked versions like a skid loader and wheeled versions .They hydraulically tilt the cab and engine portion of the machine and likewise the mowing part .No doubt they are probably very pricey .
