timberjack...
Started by The-Burl-Hunter, January 27, 2009, 06:53:24 PM
The-Burl-Hunter
hello,
I have another question on a tool used for logging or possibly firewood cutting, anyway I was on northern toolhttps://forestryforum.com/board/index.php?action=position"> Note:Please read the Forestry Forum's postion on this company looking at their logging equiptment, and ran across a timberjack, and thought that, that tool would be a great item for firewood cutting, because it lifts logs off off the ground and prevents your chain from dulling, and from the reviews that I read it sounds like a great tool, but I thought I would dig a little deeper and see what others that may or may not of uesd it may have thought, to be specific it was the northern industrial timberjack with the 4 ft fiberglass handle, or if their was any other ones that people have tried and like please leave a review or a comment thank-you all very much for leaving a comment it helps a lot. I also thought that I would find more information on it before I went and spent 80 or 90 dollars because who knows it may not be worth the money. anyway thanks  :)  :)
woodsrunner
Check out our sponsor on the left side of the page. Supporting a sponsor is a great way to support the Forestry Forum in addition to getting a top quality tool to use. I don't have one but some feel like the northern toolhttps://forestryforum.com/board/index.php?action=position"> Note:Please read the Forestry Forum's postion on this company items are a cheap knock off copy of the Logrite tools and of lower quality.
LeeB
Scroll down to the commerce section and check out Logright's answer to your question.
woodsrunner
Sorry, its been a long day. Check out our sponsor Logrite on the left side of the page.
The-Burl-Hunter
no problem thanks for the anwsers
pasbuild
I'm not going to take the time to look in northern toolhttps://forestryforum.com/board/index.php?action=position"> Note:Please read the Forestry Forum's postion on this company to see if you are talking about the same cant hook with the T attachment for lifting logs off of the ground that I have but if it is it would be the most useless piece of s##t tool you own :(
If it can't be nailed or glued then screw it
WH_Conley
Just remember, "cheaper aint always cheaper". You can get a useable tool from northern a few dollars cheaper. Would you rather have a Vega for a few years or a Caddy for a lifetime for  20 bucks more? I have never used the Logrite Hi-Jacker, what I call those things anyhow. I have used other Logrite tools enough to have faith in them though. I have also a lot of different Northern knock offs over the years to know the difference in quality.
Bill
Dave Shepard
If you can watch YouTube videos, here is a video of the LogRite log stand: Log Stand This is the one I'd buy, if it were me. And it's a LogRite Peavey too! 8)
The-Burl-Hunter
where is it on the website, maby i just looked over it but thanks for the great video
Dave Shepard
http://store.logrite.com/uls006.html
Go to "Online Store", then look for Universal Logstand on the left. It is not in with the peaveys and hooks.
The-Burl-Hunter
thank-you very much, So this is a lot better than the regular "cheap" immitations that are out their? cause it looks a lot more heavy duty but thanks for your time.
Dave Shepard
I don't have any experience with the log stand, but I've got a 60" cant hook, and have had me and another 6'3" guy hanging off of it, and it survived.  ;) I doubt you will break it unless you run it over with something.
Logrite stuff is guaranteed to for life.Not a guaranteed to get you out the door and don't come back complaining about it because it's broke.Might cost a lttle bit more,but you will learn you get what you pay for.
stonebroke
How long a cant hook should you use the lift on? A longer one would make it easier to pick up a bigger log but it might be unwieldly.
Stonebroke
