painting pressure treated
Started by bama20a, November 14, 2015, 09:49:25 AM
bama20a
Hope this is the right place to post, But can you paint pressure treated wood? It would just be for looks.Seems like I remember somewhere it said not to paint it.
It is better to ask forgiveness than permission
wildbill
i have but only after its sat out and dried out some.  seems to hold up just fine.  some of my raised bed garden boxes are PT and painted.
Raider Bill's favorite son
bama20a
It can be used and painted successfully for fascia, etc but as mentioned, let it dry for 6 months.
bama20a
Are you talking about let the paint dry for 6 mo's?
Get the wood dry, before painting ...
limbwood
I built a big deck years ago and put a dark brown stain on it, all the knots peeled off, they said you have to let it age for a year or wipe knots with denatured alcohol to dry them out . Did that and everything worked good. Good luck.
POSTON WIDEHEAD
Depending on what you are using the treated lumber for, I try to paint only 1 side. Treated lumber needs to breath.
Quote from: beenthere on November 14, 2015, 10:08:08 PM
Yup, we put it up and let it dry probably 6 months before priming and painting.  All of the fascia on the Cabin is pressure treated SYP.  I stickered it in the barn for months before using a solid base stain and then nailing it up.  The fascia on the original Cabin is 19 years old and has not peeled.
WV Sawmiller
    Good info. I used PT lumber on the bases of my shooting houses. They've been up a couple of years so if after this season if I get overly ambitious and decide to paint them camouflage sounds like they should be fine.
    (But if I camouflage them can I still find them?)
   The next one I build I'll use black locust in place of PT.
Better to use stain rather than paint.. IMO
terrifictimbersllc
We have a 30 yr old PT deck and railing that I paint every 5 yr or so. Well I use a Cabot "solid color decking stain" but it looks like paint to me.  Before repainting there is some scraping but mostly I coarse sand it first.  Don't think there's anything about the PT chemicals that make it any different with respect to refinishing. They're not volatile.
