Does anyone know what this tool is for?
Started by peter nap, October 27, 2008, 03:14:37 PM
peter nap
I can't fight the photo system here so the images and description are posted on this link. :'(
Note from admin. IMAGES MUST BE IN YOUR FORESTRY FORUM GALLERY
All you have to do is ask for help...
zopi
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
peter nap
According to Eric Sloane, it is a hay knife.
Here is other evidence.
http://www.americanartifacts.com/smma/advert/ay282.htm
Don't think the one on the arborist site will cut much ice.... ::)
peter nap
Hmmmm. It looks just like the Ice Saw, Beenthere. Maybe it was used for both :P
I imagine the "teeth" could be filed such that it just might work for both. The images, didn't show much for "teeth".
So, that is possible. That or the Museum showing it as for ice is not correct (that has happened before.. :) ).
But there is plenty of evidence it was used to cut through stacks of mowed or stacked loose hay.
Here is what I expected a hand ice saw to look like...more sharp teeth, and longer in blade length.
http://www.old-woodworking-tools.com/index/pages/073.htm
zopi
If you live in Maine, it's and ice saw...if you live in Kentucky, it's a hay knife. <G>
The real question is...Will Woodmizer Re-sharp it?
Got Wood?
And lots of junk.
The more I look at things listed as ice saws, this ain't it.
And that Kier Museum has several items mislabeled, I learned wanderin around there
(an obvious hay fork for lifting loose hay into the barn was listed as a stump puller  ;D :D).
An ice saw would have to have teeth that left a kerf wider than the back of the saw blade...or it would freeze in (i.e. get stuck). Ice saws have big teeth like a cross-cut log saw. And the handles are T-shaped, as well as the saws are much longer than this one.
Get me less convinced it is an ice saw, the more I think on it.  ;D ;D
But calls it what ya all want.  :)
JimMoore
zopi,I would not want to cut any ice with it.I'll watch while you do it. :D Ice saws teeth are many on a saw.Most I've seen are about twice as long as a hay knife.
peter nap
Thanks Guys!
I think it's a hay knife.
Looking at the pictures, it could be either...but I think the Ice Saw picture is mislabled. The edge is sharpened like a knife and since this is Virginia *even though it used to get cold before the hot air from DC started blowing this way) I don't think it ever got cold enough for the average farmer to have a dedicated Ice Saw.
zopi
Quote from: thecfarm on October 27, 2008, 10:06:06 PM
Me neither...but then i'm not gonna cut ice either..
I just googled it..
Got Wood?
And lots of junk.
peter nap
I wonder why it is I can find hay saws and pedal powered grinders but can't find a really large slick? I guess I'll have to fire up the forge and see what kind of steel is in a digging iron 8)
zopi
Got any leaf springs?
I've seen some pretty nice timber tools made with them...hard to forge tho'.
Got Wood?
And lots of junk.
iffy
An old gent that used to work for the same feedlot as my brother always seemed to have a story in him no matter what the subject. One day they were warming up in the office after cleaning feed bunks after a blizzard and my brother remarked that was the coldest work he had ever done. The old gent said the coldest job he ever had was one winter as the bottom man on a two man ice saw. ;D
peter nap
Quote from: zopi on October 28, 2008, 10:07:00 AM
Got lots of them. The older ones are 5160 and the newer ones are 1095 steel. The forge pretty well for me. 5160 is the easiest steel in existence to heat treat. What are the slick makers doing for a handle, just welding a bar on the back?
peter nap
BTW The slick I'm talking about is one of the BIG 4 and 5 inch ones with the 4 foot steel handle. I guess that's a slick.
I have a couple of the chisel length 2 and 3/4 width ones.
moonhill
Wooden Boat just did a nice article on making a slick from a leaf spring with a wooden handle.  Tempering instructions too.   They did a nice job.          Tim
peter nap
Thanks Tim!
My subscription ran out. I'll see if I can find a copy.
moonhill
zopi
Quote from: peter nap on October 28, 2008, 11:23:57 AM
figure out what the rough circumference of the handle stock is, forge the spring stock out to that width with enough length to form the socket, fold it around a rod the diameter of the handle and weld...then forge out the slick blade, or vice versa..
for one that size, I hope you have a trip hammer or something...atsa lotta work.
Got Wood?
And lots of junk.
StorminN
Quote from: peter nap on October 28, 2008, 11:35:14 AMBTW The slick I'm talking about is one of the BIG 4 and 5 inch ones with the 4 foot steel handle. I guess that's a slick.
Oh, you mean BIG ones... so this 3-1/2" White isn't big enough? (I don't own it, but wish I did!)
-N.
Happiness... is a sharp saw.
StorminN
Quote from: zopi on October 28, 2008, 10:21:09 PMfigure out what the rough circumference of the handle stock is, forge the spring stock out to that width with enough length to form the socket, fold it around a rod the diameter of the handle and weld...then forge out the slick blade, or vice versa...
Sounds like a lot of trouble, especially when you can buy a 3-1/2" slick, honed and ready to go for $160.
https://forestryforum.com/board/index.php/topic,3531.0.html
You'd have to really enjoy the forging end of things to make that worthwhile...
-N.
Dave Shepard
If you need a slick and want to get right to work, one of Jim's is the way to go. If you are into smithing, the thrill of making your own tools is a great feeling. I haven't tried a slick yet, but I can tell you without a power hammer, there's plenty of work to form that socket. I'm going to give it a try, someday. I wonder what kind of polish that leaf spring steel will take.
zopi
Quote from: Dave Shepard on October 31, 2008, 07:48:48 PM
Almost mirror if ya want to to go that much trouble...hadda friend made Bowie knives by hand out of springs...you could shave with the blade or use it as a mirror...lotta work though..
Got Wood?
And lots of junk.
