My best day so far
Started by petefrom bearswamp, March 29, 2010, 04:47:26 PM
petefrom bearswamp
Sawed 652 bd ft in 3-1/2 hrs alone today.
Norway Spruce.
Used a WM 7 degree .055 1-1/4"
You can really feed this blade fast.
Still wanders some but the stuff is dry as a bone inside.
Big logs for Norway from 18" to 22".
Pete
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Chuck White
Hey Pete; Sounds like you are getting familiar with that new Super and all of those 51 horses!  ;D
I know that Spruce can be a hard item to cut.  Sounds like you found the right blade for it and your mill.   ;)
I still use the 10° blades, exclusively.  Works for me.  8)
fishpharmer
Way to go Pete.   8)
You know having a super hydraulic is cheating ;) :D 8) 8)
Wish I could cheat like that.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
ladylake
Good job, if you have a setter try running more set in that dried out wood.     Steve
Chuck White
Hey Steve, congratulations on your 1,000th post.  ;D
ladylake
Thanks Chuck, not bad for a 1 finger typer and even then I can't hit the right key.   Steve
