Need help with clamping
Started by D._Frederick, August 08, 2009, 03:02:31 PM
D._Frederick
I am making a box-joint silverware tray that is 10 x 16 inches and the sides are 3 inch high and slope @ 20 degrees.
I need to come up with a method for clamping the box joints  corners that will hold them tight and square while the glue dries.
Any ideas would be appreciated, something simple since I am only making one.
metalspinner
Hot glueing wedges near the box joints will "square up" the box sides for your clamps to to apply even pressure.  Double stick tape will work, too. :)
I would use a picture frame jig. Made mine, and a one time clamp would be quick and easy. Would need to fashion corner blocks (as metalspinner suggests) that take out the slope of your box.
Looking for a pic.
Here is a YouTube of one on the order I made. Simpler variations are possible. I use either a pipe clamp or similar to pull the center tight.
http://www.youtube.com/watch?v=EGAKIVe-IaY
And another approach, for holding corners together.
http://www.sentex.net/~mwandel/workshop/miter.html
These blocks might be simpler to make for your box.
D._Frederick
I hot glued a small block on either side of the box joint and used a spring clamp to pull the joint tight, worked guite well. Thanks for the suggestion.
If I was making picture frames, I would get the clamp that is the shape of a "C" and has sharp points. They also would do a good job on box joints.
