Sawzall for cutting tenons
Started by stickframer, May 04, 2015, 01:07:13 PM
stickframer
Can you use a sawzall for cutting tenons or is this shun down on :embarassed:
Jim_Rogers
Use what tools you have, just make sure your end product is correct and it won't matter at all.
Jim Rogers
Dave Shepard
Welcome to the Forum!
I've never considered a sawzall to be a precision tool. It's more of a demolition expert. If you can cut clean, square shoulders with it, it would work, but that seems like a tall order.
JimXJ2000
This might also be frowned on, but you can use the side of sawzall blade to work like a rasp to trim and help shape a slightly oversized tenon.
Hilltop366
I have never tried (I am guessing you are talking about ripping?), the blades that I have used with a reciprocating saw usually flap all over the place and wander, perhaps going slow with a wider stiffer blade blade would work better.
Roger Nair
A sawzall does not clear dust well from the kerf, heat is not your friend.
An optimist believes this is the best of all possible worlds, the pessimist fears that the optimist is correct.--James Branch Cabell
witterbound
I would think using a sawsall would take a long time and be frustrating.  I do think I tried it one time.  Was unable to get the blade lined up to cut on the lines on both sides.  Don't do it.
A Sawzall is a wonderful tool for it's purpose, but precision it ain't.
fishfighter
Had used one to help cut some corner bracings due to not having the right saw. They were to thick. Ended buying a used 12" bandsaw.
shinnlinger
I would use a chainsaw before I used a reciprocating saw but how many joints you have to do?   Run a circular saw around your joint and finish with a handsaw.   It ain't too bad and pretty precise.
Shinnlinger
zopi
yeah..cut pretty close with a circular saw or maybe a very lightweight chainsaw and trim to dimension with slick and handsaw...with the circular saw, having good saw horses is a boon..
I would not use a sawzall.
Got Wood?
LT-15G GO chassis added.
WM sharpener and setter
And lots of junk.
