Pecan
Started by NWP, September 07, 2013, 03:13:53 PM
NWP
I know how some of you love to saw pecan the devil.  Here's two loads of it I got in this week. Don't get too jealous.  :D
1999 Blockbuster 2222, 1997 Duratech HD10, 2021 Kubota SVL97-2, 2011 Case SV250, 2000 Case 1845C, 2004 Case 621D, John Deere 540A, 2011 Freightliner with Prentice 120C, 2012 Chevrolet, 1997 GMC bucket truck, several trailers, and Stihl saws.
customsawyer
I have to say those are some nice looking logs.
www.thecustomsawyer.com
POSTON WIDEHEAD
That;s the most Pecan I've ever seen in one place.....in log form, that is.
Good whack there.
What's the plans for the lumber?
NWP
There'll probably be twice that amount at least by the time it gets all hauled in. Probably 20-25,000 feet. It's all going to smoke a lot of meat. I bought it from a logger that couldn't find a buyer other than pallet or firewood and the trees were coming out for a lake. Seems a shame to not be able to use it for anything other than firewood. I may haul some to the pallet mill that won't go through my processor.
Nomad
     My first thought was "All that?  Pecan?  Better you than me!!!"  But if it's gonna be mostly smoking wood you might be able to corner the market.
     On the other hand as big a pain as pecan can be to saw it really is pretty wood.  I sawed some for flooring awhile back that turned out absolutely beautiful.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
slider
You best be finding some 7 or 4 degree bands .That sure would make some nice flooring.
al glenn
mesquite buckeye
Don't forget to save some boards for the world's most pretzelly board contest. Could be some winners in there. ;D ;D ;D
woodweasel
What is so difficult about sawing pecan? I only sawed 2 approx 28'' diamX 20' !
didnt have any problens what so ever, did I get lucky or what :o ??? Daniel
hackberry jake
If I had that much pecan to saw... I would take it to the local circle mill. I would also try to make a 2' wide stack about 100' tall for enough weight to keep most of it flat.
I have found that large Pecan logs behave very well and produce some nice lumber.
Small stuff like 12"-15" and limbs can give much trouble.
You can saw it out fine, but it can be a challenge to dry straight and true unless the boards are clear and free of knots.  Around knots that are a good size, the board will get a wave in it at the knot that will not plane out easily or not at all.  Requires you to use the boards in shorter lengths.  Also tends to split and check more than most other woods that I have dried.  So, more challenge in the drying and machining area versus sawing it green, although sawing green can be a challenge too with wavy cuts and tension in the log.  It is really hard wood.
Yup, I overlooked mentioning knots.  Notice that my logs have no knots.   ;D
hackberry jake
Magic, it looks like you got away with using a slightly dull band as well based on the "strings". It also looks like you had plenty of set as well based on the sawdust on the board on the right. Plenty of set helps a lot with pecan!
You don't see pecan logs like those very often.
NWP
FF member Kcwoodbutcher and a couple of his customers came up Sunday and picked up three big pecan logs. There wasn't quite enough room on the trailer for the fourth log. We had a good visit. Hope the logs work out good.
POSTON WIDEHEAD
Wow....I think I could do something with the log that has the crotch in it. Nice logs!
NWP
Poston, I have some more if you're up for a drive.  There was 738 BF in those 3.
LeeB
How far is Kearny from Springfield? I like pecan. Cut my teeth on it. My first logs were pecan.
LeeB
Never mind. Looked it up. 300 miles plus from me.  :(
Kcwoodbutcher
That upper log got wedged in pretty tight during the trip home. Took a bit of work to pull it off. I'll start sawing as soon as it dries up again. It was a nice visit, I don't get out often.
My job is to do everything nobody else felt like doing today
grweldon
Quote from: LeeB on September 17, 2013, 07:33:40 PM
Interesting Lee.  My first logs were pecan also.  Started cutting one within an hour of the mill being delivered.  I wasn't very happy with the way the mill performed on them but I was using the 10deg. blades that came with the mill because I didn't know any better.  I'll be cutting some more within the next year and I'm sure I'll have better results.
My three favorite documents: The Holy Bible, The Declaration of Independence and The Constitution of the United States.
It's not always the fact that it is Pecan.  It may very well be the small or knotty log that is the main problem.  I have seen the slabs curl up as the faces are opened on small logs.  I had one customer that I advised what was going to happen on a small log.  Sure enough it did and he finally decided to throw the "log" off.
Good clear logs saw well.  Small or knotty, not so much.   :-\
Quote from: POSTONLT40HD on September 17, 2013, 03:07:22 PM
All my crotch pecan so far has split at the crotch  :).  Crotchety stuff to say the least.
You had better make a bench out of it because furniture will break your heart.   :-\
woodweasel
I'm in the process of  a making chest (hope chest? cedar chest?) out of
pecan ! Will post pics as I progress ! ;D
